Author Topic: List of Supported Pixels  (Read 2828 times)
Offline ron
« on: December 30, 2013, 12:26:15 AM »
Does anybody maintain a list of types of pixels that are supported by the different types of controllers? Like the F16 supports 12v 1809, 2811 and 2812 (which I don't know is correct).  I think it would be nice to have the information in the wiki for reference. Maybe a table with:
Voltage
IC (1804, 1809, 2801, 2811, etc.)
pixels per meter or spacing
Max nodes per string
Boards supported
Just starting to think about how the information could be presented. Any suggestions?  I think DLA has a partial list in their wiki.
Offline smeighan
  • Kudos: 11
    • Nutcracker123
Re: List of Supported Pixels
« Reply #1 on: December 30, 2013, 12:45:31 AM »
Voltage
Boards supported
every string supported by DLA hardware is supported by falcon-16's
in addition you can use ws2811 12v stuff.
no 4 wire (ws2801) or 5v lights are supported at this time.
so basically
12v
180x and ws2811
Sean
Offline ron
« Reply #2 on: December 30, 2013, 12:53:39 AM »
So what is the difference between the 1804 and 1809? How do those differ from the 2811? Last question for now, what new stuff do we know about that is coming that the current SSC and F16 will support?
Offline smeighan
  • Kudos: 11
    • Nutcracker123
« Reply #3 on: December 30, 2013, 01:39:17 AM »
1804 is one IC for every node
1809 is one IC for every 3 nodes. it has 9 outputs so the 3 nodes are individually addressed
i know that dave does not have any plans on supporting 4 wire lights. There has been talk about being to support 5v, we will see.
As far as the most types of lights, San Devices has the most supported: I have bolded the two types that Falcon hardware supports
The san devices has the largest supported list of leds:
GE ColorEffects pixels, 1804, 1903, 2801, 2811, 3001, 3005, 6803, 8806, 9813, and others.
I only have ws2811 and 180x stuff so i do not need any more.
Offline ron
« Reply #4 on: December 30, 2013, 07:47:27 AM »
How is the 2811 setup? It seems like I see it on some strings with individual control and then on some flex strips controlling 3 nodes.
  • Kudos: 76
« Reply #5 on: December 30, 2013, 07:58:11 AM »
The 2811 chip can only control one set of red,green and blue. The individual 5V strips you see have a 2811 built right into the LED. The 12V strips have one 2811 that controls three leds and all 3 LEDS are the same color since a single 2811 can only provide control for one set of red, green blue. I here Ray is working on a strio that can receive 12V or 5 V and will be individual pixel control. There will be four pads to solder wire to, 12V, 5V, GND and data. They are basically the 5V strips that have 2811 built into LED but with a 12V bus that has a regulator (12V to 5V) to drive the pixels.
Offline pk
« Reply #6 on: December 30, 2013, 08:38:05 AM »
I have used the left side of the F16 to power these 5V 2811's
 http://www.aliexpress.com/store/product/4m-WS2811-LED-digital-strip-60leds-m-with-60pcs-WS2811-built-in-the-5050-smd-rgb/701799_638374848.html
Here is a video of a test of the prototype of the tree topper mms and I built for our megatrees.
http://www.youtube.com/watch?v=DYsAZklikcM&feature=youtu.be
We used the above 5V flexstrip cut into eight  1/2 meter strips  (30 nodes per 1/2  meter) connected to the F16.
This is the flex strip I had at the get together in Denver.
Offline mms
« Reply #7 on: December 30, 2013, 09:23:06 AM »
This has more about the construction:
http://youtu.be/A4ihJRnDMbQ
Offline sebjsan
« Reply #8 on: December 30, 2013, 09:43:07 AM »
« Last Edit: December 30, 2013, 09:58:38 AM by sebjsan »
Offline arw01
« Reply #9 on: December 30, 2013, 11:15:10 AM »
I bought two sets of Todd's and had no issues with them.  I think after the freight from China and Todd's presale it will be really close, and Todd's do not come from Ray.
Now I am reading about a WS2812B, which I am told is also compatible with the Falcon gear via other boards and it's basically two 5050 led's so it's brighter and controlled by the WS2811.  Might be good for the in pex displays a few of us do, but I was happy with the plain Ray provided $30.00 ws2811 flex strip for some arches in plain ole Lowes/Home Depot 3/4" pex tubing.
Anyone have those to test with the WS2812B and know for sure?
Offline arw01
« Reply #10 on: December 30, 2013, 12:07:19 PM »
Now in another thread I was told it was the other way around on the TM1804 being 3 per and TM1809 being 1 per.
Quote
Alan, you say TM1804 flex strip but you probably want TM1809. The TM1804 is 3 LEDs per pixel. The TM1809 is 1 LED per pixel, so pretty tight resolution. You can definitely zip tie Flex Strip to PVC pipe. I've done it horizontally, but prefer vertical to avoid "drooping."
  • Kudos: 76
« Reply #11 on: December 30, 2013, 12:16:58 PM »
TM1804 only has three outputs (red, green, and blue). They are most used in pixel strings. I have never seen an 1804 strip. TM1809 have 9 outputs (3 sets of red,green and blue). they are used on strips and each pixel is addressable.  WS2811 are very similar to TM1804 they only have three outputs and are used for both strips and strings. When used for strips the three outputs are connected to three led's in parallel so each chip controls three leds with the same three outputs, so all leds will have same color.
