Author Topic: *Closed* 2017 Micro Hardware Co-Op - uSC, uAmp, Afterburner  (Read 22502 times)
Offline corey872
  • Moderator
  • Kudos: 16
    • Link to the sale...
« on: April 02, 2017, 04:07:43 PM »
The 2017 co-op for the Micro String Controller V1, uAmp V2 and Afterburner boards is now CLOSED
Keep an eye on this section as well as the Micro Family Hardware Section for 2018 Announcements
Please read all info and ask any questions in the regular forums before ordering.
I am still doing some testing and refinement on the 'Micro Mega Node' so it will not be part of this co-op.
Anticipated co-op closing date is July 16th after which revised totals will be calculated and payment emails will be sent.  Payment should be completed by July 23rd.  Component ordering and board production can then begin.  Circuit board etching and assembly lead time is expected to be 4 weeks total. Receipt of finished boards, packing and shipping could take approximately 2 additional weeks, which may put us at the mid / end of September for you receiving the finished boards.  I will work to speed the process where possible, and timely payments are always appreciated.
Domestic Shipping / Handling is expected to be $6.50 flat rate.  This will include a USPS flat rate shipping box, appropriate static protection bags and other consumable materials to prep for shipping.  As before I will try to offer reduced rate shipping ($3.50) for orders which fit into a small padded envelopePaypal fees will be added to each order.
International Shipping will be billed at actual cost.  Exchange rates will apply.
Prices listed below are best estimates for each component at the quantity goal listed and should be "NTE" - not to exceed.  The price listed below does not include shipping/handling, paypal fee, etc. I've tried to make best estimates for a reasonable goal on 'quantity' and price accordingly.  If we fail to reach quantity levels, I will explore other options to keep the co-op on track / on budget, though a substantially lower quantity may mean canceling that particular item.
Please do not ask for special shipping, handling, paypal transaction consideration, etc. While I wouldn't mind to do this for a few, if I do it for one, I should do it for all.  If I do it for all, then it gets to be a very complex matter of tracking all special requests, packages, shipping, special shipping orders, etc.  For this to be efficient in bulk, we need to follow a set / defined process.  I appreciate your consideration!
More info on each component:
uSCV1 controller:  Please note:
        Intro Post / Specifications - http://falconchristmas.com/forum/index.php/topic,832.msg7006.html#msg7006
        Intro Video - http://youtu.be/kozI6qHMTao
        Note on the amended test mode (ie "test mode at any time")  http://youtu.be/BBAIWbdjTpE
        Discussion on LED/indicator brightness  http://falconchristmas.com/forum/index.php/topic,835.msg7035.html#msg7035
        uSCV1 Manual:  http://falconchristmas.com/wiki/images/USC_Owners_and_Set-up_Manual_1.5.pdf
In summary, the Micro String Controller should replace the function any "SSC", but have the following benefits:  smaller, cheaper, pre-assembled, more easily waterproofed, longer controller-to-node transmitting distance, more reliable data transmission, lower overall power consumption, up to 4 indicator LEDs if desired, no-contact test mode if desired.
The board will come 100% pre-assembled, PIC programmed with the latest Falcon firmware and magnetic test switch installed.  It will be ready for channel programming, your wire attachments and then make blinky nodes.  You do not HAVE to add anything else to make blinking nodes.  Simply attach your power, data, and node wires then program channel set-up.
Four indicator LEDs will also be included which you can add to create a 'Mega' version if you wish.
Pre-Assembled/Optioned Board - $10.80
Co-op Goal:  175 boards
uAmpV2 or Micro Amp Version 2  Please Note:
As for 2016.  Same great performance, though due to popular request, the LEDs are now surface mount and will come pre-assembled.  Board size is slightly larger (about .040" more in each dimension) and hole sizes are slightly enlarged to reduce the minor wire fitment issues reported in 2015.
        A demonstration video of uAmp V1 is live at:  https://www.youtube.com/watch?v=lp8QYcV57bo
        Introductory thread with questions / answers: http://falconchristmas.com/forum/index.php/topic,2115.0.html
At the basic level, the Micro Amp is a signal conditioner / amplifier which can be used with any square wave data source.  The uAmp has been designed using the same MOSFET drive technology as the uSC and has some of the same design features such as built in strain relief holes, basic board comes pre-assembled and ready to use, pre-formed holes for optional LEDs (indicating 'power' and 'data out'),  compact size, ESD protection and short circuit protection on the data line.
Unlike the uSC, the uAmp is solely a digital signal processor.  It has no PIC chip and is not capable of differentiating different 'channels' of data the way a string controller does - it simply processes, clarifies and amplifies ANY data fed to it.  Conversely, it is a simple 'plug-n-play' device.  No PIC programming, firmware, channel setting, etc is required and you do not need to assign 'null' channels to a uAmp as you would with a null node.
Some possible uses:
If you wish to send data from an unmodified SSCV1 or SSCV2 more than a few inches, or an SSCV3/V4 more than a few feet, a uAmp can be added to the output line.  Once installed, the low power, 'messy' SSC data is amplified and clarified so the controller can now be 50, 60, 70 or more feet to the display element.
"Null Node" - Data transmission between nodes is limited to around 6-15 feet (regardless of string controller*).  Installing a uAmp after a node will condition and boost the data signal strength so gaps between elements can be 50, 60, 70 feet or more if needed.  Because the uAmp processes all data and does not use the "take one and pass it on" format a node does, the uAmp does not need to be programmed into the display, or take up channels as a null node does.
*Note - The data stream is regenerated and retransmitted by each node.  Due to this, a controller with a strong output (such as the uSC) can send data quite a far distance to the first node, however, when that data is retransmitted by the first node, the distance is again limited to around 6-15 feet.
Co-op Goal:  800 pieces   Price: $4.65 each
Afterburner - a MOSFET driver kit for Falcon F8 / F16V1 boards.
        A demonstration video is live at: http://youtu.be/c035HnwbD-E
        Introductory thread with questions / answers: http://falconchristmas.com/forum/index.php/topic,2326.0.html
        User / Install manual:  http://falconchristmas.com/forum/index.php/topic,3406.msg37135.html#msg37135
Afterburner is designed as a simple 'drop in' kit to upgrade Falcon F8 / F16V1 boards to MOSFET drive technology like that used in the uSC - Micro String Controllers.  This will boost the Falcon F16V1 or F8-to-Node distance from 20-30 feet to 50-60 feet or more.
The kit is a simple hardware board and resistor array pair requiring no programming, no setting changes, no PIC processors, etc.
One Afterburner kit would upgrade one block of 8 channels - ie one kit to fully upgrade Falcon F8, one or two kits for Falcon F16.
You can run the Falcon F16 output 'split' if desired (ie one side using the original op-amp output for local node strings, one side with the Afterburner for more remotely located strings) without diminishing the performance of either side.  If you wish to boost less than an 8 channel block, the uAmp signal conditioner/amplifier would be one option to provide the same MOSFET drive technology for individual strings.
Co-op goal: 30 pieces   Price $16.50 each
Co-op limit: 36 pieces
Please put your order request in the following format:
<preferred contact email up to but not including the @ symbol>
uSCV1 + 4 LEDs: <quantity>
uAmpV2: <quantity>
Afterburner + 9 LEDs: <quantity>
<contact email domain>
**Note - email is formatted to keep any spambots from scraping the forum.  If your email is john.doe@email.com, you would enter
'john.doe' in the <preferred contact email not including the @> space, then enter 'email.com' in the <contact email domain> space.
EXAMPLE ORDER FORMAT (please feel free to cut and paste as needed)
<john.doe>
uSCV1 + 4 LEDs: 6
uAmp: 12
Afterburner + 9 LEDs: 1
<email.com>
As time allows, I will post and update a table of order quantities in the next post.  Please double check it for accuracy, as well as your payment email.  Your payment email will be based on the table and your order will be based on your payment email.
[I anticipate this thread remaining open to Saturday July 16th.  Please take your time, read carefully, consider your order and payment carefully.  Please ask any questions in the normal forum before ordering.]
Thanks for your attention and patience.
« Last Edit: January 29, 2018, 05:29:35 PM by corey872 »
Corey
 2018 uSC, Afterburner, uAmp co-op - pending May-June 2018.  Remaining boards are now FOR SALE
Offline corey872
  • Moderator
  • Kudos: 16
*Shipping* 2017 Micro Hardware Co-Op - uSC, uAmp, Afterburner
« Reply #1 on: April 02, 2017, 04:08:09 PM »
2017 Micro Hardware Co-Op - uSC, uAmp, Afterburner Co-Op Order Sheet
You should receive a paypal notification when your shipping label is printed.  "Shipped" listed on this table means your order has been delivered to the post office.  It may take an additional 24+ hours for the post office to get the tracking number "in the system"
Please DOUBLE CHECK your order on arrival.  If you note any discrepancies please PM me as soon as possible.
Extra boards will go on sale after the co-op orders are shipped and any order issues are rectified, so keep an eye on the For Sale section.  Thanks!
UsernameuSCuAmpAfterburnerShipping
aclarksr4100Shipped
adamb050Shipped
adster080Shipped
ahb2ukeith0120Shipped
aknflyer0300Shipped
andrews_texas0200Shipped
andyaz0250Shipped
b0nafide050Shipped
Bhoff0100Shipped
Buckeyelights0100Shipped
camguy520250Shipped
Cdanna770100Shipped
cody33rd0100Shipped
CW0160Shipped
DearJoel050Shipped
dennismccreery10102Shipped
drbenj10200Shipped
epnicass3150Shipped
ERicJ0100Shipped
FIRECOP2520100Shipped
fyb20000200Shipped
goofytruax0200Shipped
iamthegeek0200Shipped
jboogie7140300Shipped
jchancel070Shipped
jhoybs050Shipped
JimWright0300Shipped
Ken0500Shipped
kevinp0100Shipped
khengyu0500Shipped
knightrohulk0200Shipped
K-State Fan0120Shipped
larryk50200Shipped
lrhorer8400Shipped
lwillisjr0100Shipped
madams1370100Shipped
mararunr0100Shipped
MattBrown0200Shipped
Michael0120Shipped
mklabunde5300Shipped
mlbarber210400Shipped
mndless0300Shipped
nmiller01130100Shipped
PeteyHall0150Shipped
PIC1080Shipped
rmp29171000Shipped
ReelPaws0150Shipped
shane12340150Shipped
Steve Gase2000Shipped
tractormike2110100Shipped
Unibits0120Shipped
WarDawg050Shipped
Wichita0100Shipped
« Last Edit: September 16, 2017, 06:47:35 AM by corey872 »
Offline corey872
  • Moderator
  • Kudos: 16
Re: Pending ** 2017 Micro Hardware Co-Op - uSC, uAmp, Afterburner and ???
« Reply #2 on: April 02, 2017, 04:08:22 PM »
Reserved
Offline knightrohulk
« Reply #3 on: April 02, 2017, 05:35:20 PM »
Subscribed!
Offline chadowamsley
« Reply #4 on: April 04, 2017, 02:32:12 PM »
Will be waiting
Offline K-State Fan
« Reply #5 on: April 18, 2017, 05:01:15 AM »
Subscribed
Offline goofytruax
« Reply #6 on: April 18, 2017, 07:57:53 AM »
Any update?  I'm impatiently waiting :)
Offline lwillisjr
« Reply #7 on: April 25, 2017, 06:36:55 PM »
Me too!
Offline corey872
  • Moderator
  • Kudos: 16
I've added a bit of update along with the pending new board intro:
http://falconchristmas.com/forum/index.php/topic,7257.msg70064.html#msg70064
Hoping to kick everything off soon.
Offline n0kjf
I'm still learning, I think I need in.  I have a few runs to get over 100' to the start of my lights.
Lew
Offline PIC
Subscribed
Sent from my iPad using Tapatalk Pro
PIC
 1-FPP 1-EtherDongle 1-Zeus 8 2-ActivePort Hubs
Online JonB256
  • Kudos: 126
Lew
100 feet to the lights - you could use multiple uAmps or just use the Differential boards that go with the F16v2, F16v3 or the very new F4v3. The differential method goes LONG distances to first pixel.
Offline mbarber21
Any word on the micro amp co-op.
Offline epnicass
« Reply #13 on: June 05, 2017, 01:37:43 PM »
I am interested on ordering 15-20 Amp for my Christmas 2017 display. Has the ordering began or it is too late?
Regards
Emir P.
Offline b0nafide
  • Newb
« Reply #14 on: June 05, 2017, 01:41:43 PM »
Still nothing as far as I've seen. I'm waiting on the announcement to begin as well.
- b0nafide
