Author Topic: PiCap built but can't test strings  (Read 9488 times)
Offline travcam
  • Kudos: -1
« on: April 08, 2017, 12:48:02 PM »
Earlier in the year I purchased a PiCap to experiment with.  I just received my pixel preorder from Jan and now I'm trying to get everything playing together.
I've got the Pi and the PiCap together, installed FPP and checked (triple) the jumpers.
I started with a 50 pixel string on port 1 as RPIWS281X as the noob walkthru and video describe which puts me at 150 channels.  I'm running 12v ws2811 pixels.
When I try to run a test output for those 150 channels, I get nothing.
I checked output voltage on the PiCap to the pixels and it's 13.4 which seems appropriate for 12v pixels.  I have a 60 amp power supply.
Anyone know whatelse I can try or test to figure out my problem?  I've already re terminated the pos/Data/neg wires and tried different pixel strings to no avail. I've never ran these lights, so I can't say they work, but when I plug them in, they do flicker blue briefly.
  • Kudos: 68
Re: PiCap built but can't test strings
« Reply #1 on: April 08, 2017, 02:54:31 PM »
13.4 is pretty high.  Lots of folks have had to turn their power down to 11.5 - 11.8 to get good results.
Offline patdelaney
  • Kudos: 9
« Reply #2 on: April 08, 2017, 02:57:18 PM »
I know this may go without saying ... but are you sure you are following the arrows on the strings.
You can only feed the string from one end for data, maybe you have the string reversed?
Pat
Offline AAH
  • Kudos: 19
  • Blinky blinky blinky
    • I love blinky lights
« Reply #3 on: April 08, 2017, 04:23:08 PM »
Pop up some screenshots of the network configuration and the output config pages. Something may have been missed.
Offline travcam
  • Kudos: -1
« Reply #4 on: April 08, 2017, 08:55:46 PM »
Pat
These are WS2811-12v Pixelstring 18AWG from DIY LED Express.  I don't see any arrows on them...the pigtails I received only fit one connector per string and won't mate the other way.
Just for kicks, I took the data and tried feeding it thru the opposite end using a pin and jumper.. no luck
Offline travcam
  • Kudos: -1
« Reply #5 on: April 08, 2017, 08:59:50 PM »
Here are the network and output pages.
Note: I have the active box checked and saved...  i snapped the pic after trying other things.  Sorry
« Last Edit: April 08, 2017, 09:11:41 PM by travcam »
  • Kudos: 127
« Reply #6 on: April 08, 2017, 10:12:21 PM »
Check the "Active" box on the second screen shot. You have it configured but not actually loaded correctly.
Offline travcam
  • Kudos: -1
« Reply #7 on: April 09, 2017, 09:08:46 AM »
I've done that and saved it and restarted FPP.  Same result.
Offline David Pitts
  • Kudos: 80
« Reply #8 on: April 09, 2017, 04:15:16 PM »
Do you have the green power light lit on PiCap?
Offline travcam
  • Kudos: -1
« Reply #9 on: April 09, 2017, 08:24:42 PM »
Yes
Sent from my iPhone using Tapatalk Pro
  • Kudos: 127
« Reply #10 on: April 10, 2017, 06:55:55 AM »
As pictured, Red is almost always the POS V, but you may have white and blue swapped.
Offline Jonnyb44
« Reply #11 on: April 10, 2017, 03:35:10 PM »
How are you testing? From xlights or fpp test page?
Offline travcam
  • Kudos: -1
« Reply #12 on: April 14, 2017, 08:36:04 AM »
Traced the wire colors to the circuit board in the bulb and the white wire is data, blue is ground.  So it should be wired properly.
Offline travcam
  • Kudos: -1
« Reply #13 on: April 14, 2017, 08:41:40 AM »
Testing from the FPP test page.  I used the noob setup guide from the forum.
http://falconchristmas.com/forum/index.php/topic,6139.0.html
I figured it was best to get that working independently before I started messing with xlights... so far my experience in the hobby is limited to renards and vixen.
Offline Jonnyb44
« Reply #14 on: April 14, 2017, 08:43:23 AM »
Those should light from display testing. As long as they are 12v ws2811
