Author Topic: F32B  (Read 2545 times)
  • Kudos: 80
F32B
« on: May 18, 2017, 02:09:07 PM »
While waiting for some stuff to test my F8B, I decided to try and create another board that uses more of the BBB.   I decided to try an F32-B that has 32 local output, 2 differential ports (8 strings total) and 2 other differential ports that can be used for 8 DMX/PixelNet or to more sets of strings.   First problem:  Eagle "free" board size restriction.  Thus, I flipped over to KiCad and redid a lot of stuff.   Couple days of learning and I now have things laid out.   It's a bit tight as I was trying to keep it to 15cm x 15cm to keep the elecrow cost down a bit.  Going up to 20cm in either direction will jump the cost by at least $2/board.
Anyway, once I'm back from a work related trip, I hope to be able to test the F8B stuff and finalize that.  I'll likely then order some boards.  :)
Offline JerryPlak
Re: F32B
« Reply #1 on: May 18, 2017, 03:51:29 PM »
Cool
Jerry Plak
  • Kudos: 119
Re: F32B
« Reply #2 on: May 18, 2017, 08:20:42 PM »
In the spirit of 1980's computers - who would ever need that many outputs?
Offline Phrog30
  • Kudos: 8
Re: F32B
« Reply #3 on: May 19, 2017, 05:57:26 PM »
People that don't like power injection and insist on running only 100 pixels per output would probably be all over it.
Sent from my Pixel using Tapatalk
  • Kudos: 80
Re: F32B
« Reply #4 on: May 19, 2017, 06:36:17 PM »
Yep.  That's exactly what I'm going to use it for.   My megatree currently uses an F16-B with an expansion port for 32 outputs.   My matrix on my bushes is currently 14 strings on an F16-B, but I'm expanding it to 28 strings next year and was planning on just adding an expansion board there to match the mega tree, but since I'm designing boards and such I decided to just design a single board instead.
Offline arw01
Re: F32B
« Reply #5 on: May 22, 2017, 02:55:12 PM »
pulling up a chair..
I like less on an output, but was shy of a few outputs last year.  Less of your show goes dark if you have an issue.
  • Kudos: 80
Re: F32B
« Reply #6 on: May 22, 2017, 08:01:54 PM »
I need to test the differential outputs to make sure I have the pinouts correct.   I've just been very busy.  Baseball, Soccer, and Lacrosse season keeps me busy with the kids this time year.   I'm hoping to test that out sometime this week.
I've tried to keep the board under 15cmx15cm since the cost at elecrow jumps pretty bad when one of the dimensions goes above that.   That said, the parts are the killer.   The 33 fuse holders themselves are $25 at digikey.  I think all the parts are about $90 or so.  (for quantity 1) Some parts are cheaper at mouser, but I haven't really priced everything out yet.
Offline gadgetsmith
  • Kudos: 14
Re: F32B
« Reply #7 on: May 23, 2017, 08:18:03 AM »
Some people include things like fuse holders when doing a group buy on boards as they can be purchased in bulk from AliExpress and such at a discounted rate... of course that's more work for you if you decide on a group buy, which might not be something you want to do.
Here is one link, and fuse holders are $0.15/ea.
Free shipping.Small car fuse holder PCB board sold small even clip seat car seat even trumpet trumpet Insur Slide
 http://s.aliexpress.com/vyUV3yuq
(from AliExpress Android)
  • Kudos: 80
Re: F32B
« Reply #8 on: May 23, 2017, 08:48:11 AM »
Yea... Dave sent me an ebay link for the pixel connector/socket things as I couldn't find the right one available at Digikey or Mouser.   Thanks for the fuseholder link (and a link at the bottom had good prices for the 5amp fuses).   There is definitely some savings for various things via other routes.    I think my next step will be an "interest" thread to see if there is enough interest for a group buy.  I can use the higher Digikey values as a "maximum" for the interest.
  • Kudos: 80
Re: F32B
« Reply #9 on: May 31, 2017, 09:16:00 AM »
I've created an interest thread at:
http://falconchristmas.com/forum/index.php/topic,7318.0.html
to see if it's worth running a group buy.
  • Kudos: 80
Re: F32B
« Reply #10 on: June 12, 2017, 06:39:26 AM »
Since it looks like everyone thinks its worth it to get it pre-assembled, I went back and redid it using surface mount resistors (which are free at elecrow).  Surface mount parts are cheaper to mount as well (3 cents per pad instead of 4 cents).   I also decided to add surface mount fuse indicator LED's which kind of offset the savings, but I think are a valuable addition.
For the F32-B, I also had space to widen the ethernet cutout (no space for this on the F8-B unfortunately).   This is to allow for using a Beaglebone Green Wireless which has the 4 USB ports there.   I'm working on a new image that will work for the two wireless boards (BBGW and BBBW) as well as the wired boards with (or without) EDM wifi adapters.  I have all 4 Beaglebone types sitting here on my desk.  (actually, I have 5 as I also have a red BBB Industrial)   :)
Anyway, the final assembled cost (qty 20) fully assembled will be $79 + shipping.   I will be starting  the group by later today.
Offline jaysdisaster
Re: F32B
« Reply #11 on: August 22, 2018, 09:15:27 AM »
Is the f32 set up for multiple power supplies or is v1-v4 a bus system ?
Sent from my SM-G920T using Tapatalk
  • Kudos: 80
Re: F32B
« Reply #12 on: August 22, 2018, 08:00:03 PM »
Each group of 8 outputs has it's own power terminals.  The only "special" one is V1 which also powers the BBB
Re: F32B
« Reply #13 on: August 22, 2018, 09:02:27 PM »
Thank you Dan that's awesome.
Just double checking is mixing 12v and 5v in different groups ok ?
  • Kudos: 80
Re: F32B
« Reply #14 on: August 22, 2018, 10:40:16 PM »
Yep.   Each of the 4 groups can have it's own voltage and power supplies and such.   Just e careful with the first group to make sure the jumpers are properly set for the voltage you are applying.
