Author Topic: WANTED: Display Random Image script  (Read 1004 times)
Offline z0mbieSt0mp
« on: May 12, 2017, 07:22:38 PM »
I will be utilizing still images in my show this year, but I was wondering if someone had a "display RANDOM image script"?
Since all images remain in the uploads directory, it could be pretty simple to write (maybe?)
What language are the FPP scripts written in?
Offline z0mbieSt0mp
Re: WANTED: Display Random Image script
« Reply #1 on: May 12, 2017, 07:30:07 PM »
While we are on the subject, I noticed the Display Static Image script remains on the screen forever, even if you play a video, after the video ends it goes back to the last displayed image.
Is there a script to close (turn off) the image and go back to nothing?
Offline patdelaney
  • Kudos: 9
« Reply #2 on: May 13, 2017, 07:16:38 PM »
Just for clarification ....
Display random image on a Matrix or Video output via Projector?
Pat
Offline z0mbieSt0mp
« Reply #3 on: May 13, 2017, 08:52:03 PM »
Sorry, HDMI output to a monitor (or projector)  ;D
Offline patdelaney
  • Kudos: 9
« Reply #4 on: May 14, 2017, 05:52:36 AM »
are you going to want the images "all the time" or are they going to be "filler" in between other things like videos playing?
Pat
Offline z0mbieSt0mp
« Reply #5 on: May 14, 2017, 09:55:59 AM »
Sorry again, I should have explained further.
My display has a 22" monitor for "signs" and a projector
The script i am inquiring about is for the monitor (still images only)
Offline patdelaney
  • Kudos: 9
« Reply #6 on: May 14, 2017, 04:12:04 PM »
All images, all the time? :-)
Just want to be sure
Offline z0mbieSt0mp
« Reply #7 on: May 14, 2017, 07:14:55 PM »
On the monitor, all images all the time, yes...
The projector, however, will be doing video
  • Kudos: 182
« Reply #8 on: May 17, 2017, 02:56:43 PM »
You can use the 'fbi' utility to display images in a random order.  fbi is installed on the FPP SD image, so you should be able to test from the command line and make a script to do what you want.
Here's a link to some more info including the command line option for randomizing image display.    http://www.raspberrypi-spy.co.uk/2017/02/how-to-display-images-on-raspbian-command-line-with-fbi/
Offline z0mbieSt0mp
« Reply #9 on: May 19, 2017, 06:33:10 PM »
thanks, I will give it a go
