Author Topic: uAmp, uSC and Afterburner After Co-Op Sale is ON  (Read 3524 times)
Offline corey872
  • Kudos: 16
    • Link to the sale...
« on: October 01, 2017, 11:02:38 AM »
The post co-op sale for uAmp, uSC and Afterburner is OPENPlease read carefully:
- No need to post your order here.
- uAmp, $4.75 each - Sold Out for 2017.  Watch for 2018 co-op announcements, May - June 2018.
- Afterburner, $17.00 each -
approx. 12 left
- I also have 4 'Blue Dot' uSC V2's from the 2016 co-op for a flat rate of $40.  These function identically to all other uSC's but were assembled with a slightly different variant of the PIC chip and use a different firmware version (pre-installed).
- $3.50 US shipping, $7.00 foreign shipping.
Simply add up the number of units you wish to purchase and add shipping.  The total payment can be submitted to my paypal account PayPal Me
- Be sure to list your intended order quantities in the PayPal note section.
- Be sure to use the 'Goods and Services' option so PayPal will forward your shipping address.
- Be sure to read above carefully, add your order carefully and make accurate note of your purchase in PayPal. Limited quantities are available.
- If there are discrepancies in your order quantities or payment, I will contact you for clarification, though other orders will be processing at the same time and stock will eventually run out.
If there are any questions, feel free to post here.
Corey
« Last Edit: February 03, 2018, 07:17:38 AM by corey872 »
Corey
Offline txag2008
Re: uAmp, uSC and Afterburner After Co-Op Sale is ON
« Reply #1 on: October 04, 2017, 12:03:12 PM »
Corey, I am wanting 2 uSC's. Should I go ahead and PayPal you now or what until you confirm availability? (Since there are no other replies to your original post I wasn't sure if people were dealing direct with you through Paypal or not.)
Offline corey872
  • Kudos: 16
« Reply #2 on: October 05, 2017, 08:10:00 PM »
Yep - the sale is open, feel free to paypal your order with the instructions above and I will get it shipped out.  Stock is good on all parts for the moment.
Corey
Offline txag2008
« Reply #3 on: October 07, 2017, 03:23:55 PM »
Corey
Thanks for the reply Corey.  My needs have now changed and I'm no longer in need of the 2 USCs.
Offline bowhunter3125
« Reply #4 on: October 17, 2017, 01:10:51 AM »
Forgive my ignorance, but what are these?
Offline corey872
  • Kudos: 16
« Reply #5 on: October 17, 2017, 08:57:41 AM »
Should be pretty well covered in the manuals and videos stickied in the Micro Family Hardware section.
Offline kickercivic1
« Reply #6 on: October 26, 2017, 03:26:23 PM »
Afterburner would it work on F16V3 board? or have to do with Uamp route?
Offline corey872
  • Kudos: 16
« Reply #7 on: October 26, 2017, 08:52:41 PM »
Afterburner was developed for the F16 / F8 V1's.  I 'think' the V2 and V3 use the same driver chips (possibly someone can confirm), so the afterburner should work as a replacement in those boards, too.  However, there may be issues with the Afterburner board overhanging some of the connectors or other components.  So basically, I can not confirm they work / no testing has been performed, so it would be an 'experimental' case at best.
Offline Ryanssking
« Reply #8 on: October 26, 2017, 10:55:52 PM »
How many of the uAmps are left?
Offline pblais
« Reply #9 on: November 16, 2017, 12:51:07 PM »
Hi corey
what do I need to do to order a couple uSC boards?
  • Kudos: 67
« Reply #10 on: November 16, 2017, 02:38:43 PM »
read the first post.
Offline MikelMD
« Reply #11 on: December 07, 2017, 10:19:10 AM »
New to the uAmp, uSC and Afterburner tech.  I now understand what the uAmp can be used for, what about the uSC and Afterburner?
Offline lightingGURU
« Reply #12 on: February 04, 2018, 05:44:06 PM »
When is the next group buy going to be for the uAmp?
Offline Cjaqua
« Reply #13 on: February 04, 2018, 05:48:02 PM »
Not sure but David Pitts is coming out with a Falcon Amp (F-Amp). He expects it to be ready in a month.
  • Kudos: 67
« Reply #14 on: February 05, 2018, 08:47:55 AM »
Been announced that it will probably be late May.
