Author Topic: Trouble programming F-16 v1  (Read 817 times)
Offline chadowamsley
« on: October 02, 2017, 04:17:33 PM »
Hello,
Im having issues accessing the wiki, so I was hoping to get some pointers on what to check. Im reprogramming my F-16 boards from last year, one takes programming, but the other does not. Im trying to program the 2 boards with the exact same info. I have the universes on the boards matching but still no luck. Not sure which chips I can try swapping without being able to access the wiki. Wiki mentions something about [/size]PSR-3 logging library and says I must install something on my end. Any help would be appreciated.
  • Kudos: 116
Re: Trouble programming F-16 v1
« Reply #1 on: October 02, 2017, 05:23:20 PM »
They probably don't have the same PIC firmware.
« Reply #2 on: October 02, 2017, 07:43:45 PM »
I programmed them last year with correct channels using the Falcon programming tool. I shut them down for the night and will look at it again in a day or two. Taking a break seems to help sometimes.
