Author Topic: BBB with FPP 1.9-73 rgbcape48c problem  (Read 506 times)
Offline zxzx1562
« on: November 09, 2017, 06:29:10 AM »
I use the RGBCape48C with BBB and with 27 output(total 4950 node)
but the LED run with noise and strange...
When i use LED test card the led runs good
but use the BBB the problem show up.
My fpp version is 1.9-73
How can i fix the problem??
  • Kudos: 182
Re: BBB with FPP 1.9-73 rgbcape48c problem
« Reply #1 on: November 11, 2017, 12:44:25 AM »
Are you using the FPP v1.5 BBB image and upgrading to v1.9?  If so, I would recommend reinstalling using Dan's new BBB image which has quite a few BBB related bug fixes and enhancements in it.  We will get these merged into the main FPP code after the holidays, but for this year I would recommend running Dan's BBB image.
Offline zxzx1562
« Reply #2 on: November 11, 2017, 07:18:23 AM »
no
i try those two version but same problems... :'(
Offline zxzx1562
« Reply #3 on: November 12, 2017, 08:21:21 PM »
https://imgur.com/a/qh5DJ
this is my config
  • Kudos: 182
« Reply #4 on: November 15, 2017, 01:08:49 AM »
Try setting all your outputs to 40 pixels each and seeing if the problem goes away.  Having some outputs at 40 nodes and one at over 300 could be causing issues since the code has to loop 300 times for all outputs due to the way it works.
By "two versions" are you referring to v1.5 and upgrading to v1.9 or do you mean that you have also tried Dan's SD image? I would definitely try Dan's newer code for the BBB if you are running 300 pixels on one output.
Offline zxzx1562
« Reply #5 on: May 07, 2018, 03:25:32 AM »
each 40 nodes solve the problem.
but now i have each one 120 nodes X 64 LED(total 7680 nodes)
how to solve the problem with RGBCape48C...?
