Author Topic: F16v1 Not Passing a PixelNet Signal Through Properly  (Read 1769 times)
Offline Gary
« on: November 10, 2017, 12:47:34 AM »
It looks like I have a F16v1 (I'll call it Controller 1 for clarity's sake) that isn't passing a Pixelnet signal properly from the Output 1 or Output 2 jack.
When in FPP Test mode, Controller 1 is getting a PixelNet signal from my F16-B and shows the test pattern on a test pixel string just fine, but another F16v1 I have (I'll call it Controller 2) daisy chained to Controller 1 using either the Output 1 or Output 2 jack doesn't have its test pixel string show the test pattern. However, the Pixelnet LED on Controller 2 flashes quite happily. :)
At first, I thought that it was Controller 2 that was at fault, but if I take the Pixelnet cable from my F16-B directly into Controller 2, the test pattern flashes fine. I also have a Controller 3 that can pass PixelNet to Controller 2 and Controller 2 shows the test pattern fine.
If it's relevant:
Controller 1 is on Pixelnet Universe 2 & 3 (has Active Pixelnet)
Controller 2 is on Pixelnet Universe 3 & 4 (has Passive Pixelnet)
Controller 3 is on Pixelnet Universe 1 & 2 (has Active Pixelnet)
For clarity's sake, I can take the Pixelnet output from my F16-B and plug it directly into each of my F16v1 controllers one at a time, and the test pattern works on them all.
What could be the problem with Controller 1? All 4 universes of Pixelnet should simply pass through from one controller to the next, whether a controller is programmed to do any blinky flashy with the channels/universes or not, correct?
Offline zwiller
  • Kudos: 13
Re: F16v1 Not Passing a PixelNet Signal Through Properly
« Reply #1 on: November 10, 2017, 07:52:48 AM »
Head scratcher...  I tend to agree that it shouldn't matter and just passes PN BUT I swear I ran into the same thing before and jumpers were off.  I think there is a little more going on than the just wire pair (I think the signal must return or something).  Also had a similar issue and it was simply the dang cat5 cable.  Maybe old or corrupt firmware on Controller 1?  Reflash maybe.
Maybe related? http://falconchristmas.com/forum/index.php?topic=615.0  At work but pretty sure all of my F16v1 are passive.
Sam
Offline rdebolt
    • Christmas in Boise
« Reply #2 on: November 10, 2017, 12:47:58 PM »
With Controller 1 being an "Active" pass through you may have a problem with one of the 490 chips. What happens if you remove the chips and install jumpers to make it passive and not active? With Active the pixelnet is getting regenerated and it may not be regenerating correctly. Or you could swap the chips between the 2 active controllers and see if the problem follows them.
Roger
Offline Gary
« Reply #3 on: November 10, 2017, 02:21:29 PM »
The controller in question with Active Pixelnet doesn't have anywhere to place jumpers (nothing is soldered into that spot--the circuit board is just bare there). I see in http://falconchristmas.com/forum/index.php/topic,615.msg4516.html#msg4516 there is a suggestion of removing the 4 chips and putting in wire jumpers, but the image was deleted, so I wouldn't know where to put them.
The thing is... is each chip for one PixelNet universe (i.e. 1 wire pair)? Which one is responsible for sending the signal to make the next controller in the daisy chain make its Pixelnet status light flash? Or would "scrambled noise" caused by a bad chip on Controller 1 in turn being received by Controller 2 make Controller 2 "satisfied" enough to make the Pixelnet status light flash?
Offline Gary
« Reply #4 on: November 10, 2017, 02:24:10 PM »
I checked, re-checked, and checked again my jumpers and Falcon Controller Software setup as well and they all look. I checked some cables recently with a CAT5 tester, but I'll check the ones in question again.
Offline zwiller
  • Kudos: 13
« Reply #5 on: November 10, 2017, 03:47:59 PM »
Pics of my v1.0.  At this point I am with Roger, pull chips and jumper.  Good luck!
  • Kudos: 118
« Reply #6 on: November 10, 2017, 04:00:02 PM »
note that the jumpers on Max3 are "odd" in that they crisscross. One jumper is on the underside of the board.
Offline rdebolt
« Reply #7 on: November 10, 2017, 09:22:29 PM »
Before soldering anything you might do what I suggested and swap the chips one a t a time and test on working controller. I may be able to find a chip if you need one. I'm not 100% on that and I would need to do some digging, but let me know.
Roger
Offline zwiller
  • Kudos: 13
« Reply #8 on: November 11, 2017, 06:41:31 AM »
Thanks for pointing that out Jon, that is the actual issue IIRC.  So controller 1 is v1.0 and controller 3 is v1.03?  Maybe just some cat 5 wire in the sockets.
Offline Gary
« Reply #9 on: November 11, 2017, 06:54:41 PM »
If I find only one chip is bad, can I do the ol' "stick wires into the IC socket" trick for just one socket, or is it all or nothin'?
  • Kudos: 118
« Reply #10 on: November 11, 2017, 07:08:15 PM »
You could just do just that one. Those chips just "clean and amplify" a potentially weak Pixelnet data stream. If you don't need to pass all four Universes, just put good chips in the sockets for the two Universes you want to pass.
Offline Gary
« Reply #11 on: November 12, 2017, 11:12:33 PM »
I was removing the chips and noticed that one was coming out much easier than the one previous. Upon closer inspection, the whole socket was coming out. I turned the board around, and it looks like 2 of the sockets were only tacked/soldered in by two pins.  ::)  In my defense, I didn't assemble the board myself.  ;D
I soldered the rest in place and all is good now.  :)
Offline rdebolt
« Reply #12 on: November 13, 2017, 08:02:36 AM »
Glad you got it going Gary!
I am still fighting! >:(
Roger
Offline zwiller
  • Kudos: 13
« Reply #13 on: November 13, 2017, 08:11:45 AM »
+1;  Must not be the first version board.
Offline Gary
« Reply #14 on: November 13, 2017, 09:51:46 PM »
Why do you say that? Did you have a similar issue with your F16v1.03 board?
