Author Topic: custom grouping  (Read 1011 times)
Offline FireMedic4Christ
custom grouping
« on: March 31, 2014, 01:02:37 AM »
Looking to make some pixel icicles like this.
   -- 1    10----11     20----21
       2     9     12      19     etc
       3     8     13      18
       4     7     14      17
       5___6     15___16
Will the grouping software allow me program one strand of nodes as icicles and a single roofline? Based on the graphic, i would need to group node 1, 10, 11, 20, 21, etc?
Thanks in advance,
Brian
Brian
  • Kudos: 76
Re: custom grouping
« Reply #1 on: March 31, 2014, 01:17:03 AM »
Brian,
You most likely want ability to address each node so grouping is not what you are looking for. Your diagram looks like a vertical matrix, starting in left upper corner. string count of 10, 2 strands per string in Nutcracker.
Re: custom grouping
« Reply #2 on: March 31, 2014, 07:15:37 AM »
I have several ideas as far as programming goes, I was just hoping I would not have to pick out each node in the "roofline". Right now, I am thinking I want to put a C9 cover on each of those and use just nodes for the "icicles" hanging below them. If not grouping, my next option I think is creating a model for each in nutcracker.
Thanks,
Brian
  • Kudos: 76
Re: custom grouping
« Reply #3 on: March 31, 2014, 09:54:16 AM »
For the roof lines grouping could work for you. Custom grouping or standard grouping. Use custom grouping if the groups are different sizes. PM sent.
