Author Topic: do i need a RasClock  (Read 314 times)
Offline Smithbuilt
« on: December 13, 2017, 02:46:12 PM »
I thought that I read somewhere that if my Pi is always connected to the internet, I do not need an RTC add-on. Is this true?
What should I use in NTP server
Thank you
Offline deanathpc
    • Brooks Family Lights
Re: do i need a RasClock
« Reply #1 on: December 13, 2017, 09:40:23 PM »
That is in fact true.  It will sync to the time servers.  If you plan on removing it from internet access though you will want to install the RasClock.
Dean
Stafford, NY
FPP, F16v2R's, LE's, xLights
Offline tbone321
  • Kudos: 46
« Reply #2 on: December 14, 2017, 09:39:38 AM »
A RasClock is only needed if you are going to be running the PI is a situation where it doesn't have access to the internet.  None of my PI have one and they work just fine.
Offline Smithbuilt
« Reply #3 on: December 14, 2017, 10:01:11 PM »
Thank you.
What do you have for the NTP server?
Sent from my SM-T210R using Tapatalk
Offline tbone321
  • Kudos: 46
« Reply #4 on: December 15, 2017, 06:04:57 AM »
I did not select one.  You can leave that blank and it will use its default server.  I just set the time zone and it took care of the rest.
  • Kudos: 54
« Reply #5 on: December 15, 2017, 09:45:29 AM »
I have been using FPP since it first came out and have never set a specific ntp server.  There is no need to specify one.
« Reply #6 on: December 15, 2017, 10:01:25 AM »
FPP pulls NTP servers using DNS normally but if DNS isn't working then NTP won't work by default.  I think that is likely some users issue.  They don't notice that DNS isn't working unless they need to pull in an update but noticing that the time is off is easily seen.
