Author Topic: Channel range limitation ?  (Read 624 times)
Offline Gerry
« on: January 27, 2018, 03:40:33 PM »
Hello,
 Does the 32,767 range limitation (between the lowest start channel and the highest ) still apply ?
And if yes, is there an upcoming firmware release that will enable a greater (non adjacent) ranges ?
I am running version 1.09 on an F16V2 .
Attached is the error message received whilst attempting to add a new universe outside this range
(and in case the image does not attach), the message says "This start channel creates channels outside the range of 11450 to 44217"
11450 is the lowest existing channel and I attempted to add a new universe with a channel starting at 45,000.
http://falconchristmas.com/forum/index.php/topic,6416.msg62842.html#msg62842
« Last Edit: January 27, 2018, 05:42:56 PM by Gerry »
Gerry
Online David Pitts
  • Kudos: 75
Re: Channel range limitation ?
« Reply #1 on: January 27, 2018, 08:39:05 PM »
Use universe / start channel mode and there is no limitation.
Offline Gerry
« Reply #2 on: January 27, 2018, 10:05:34 PM »
Thanks David
