Author Topic: Fpp jacking up home WiFi  (Read 421 times)
Offline Hawkeyegrafix
« on: February 10, 2018, 11:57:23 AM »
So when I plug in the fpp I can access it wireless but nothing else can access the WiFi til I turn off fpp, what would be causing this?
Online CaptainMurdoch
  • Kudos: 192
Re: Fpp jacking up home WiFi
« Reply #1 on: February 10, 2018, 12:48:16 PM »
Sounds like either E1.31 traffic on WiFi or maybe you have a bad static IP on the Pi/BBB causing routing issues.
« Reply #2 on: February 10, 2018, 02:27:10 PM »
Thanks CaptainMurdoch, I give up on static, switched to dhcp and everything works
  • Kudos: 116
« Reply #3 on: February 10, 2018, 03:33:51 PM »
Sounds like you gave it the same Static IP as your Wireless Router. That would definitely cause the problem.
« Reply #4 on: February 12, 2018, 10:24:09 AM »
No it was 192.168.5.100 didnt think that would be a problem?
Offline Kjam22
« Reply #5 on: February 13, 2018, 07:58:58 AM »
I had a similar issue because I had the same IP as my sons Xbox.  Screwed up everything
