Author Topic: Controller Upload Question  (Read 592 times)
Offline mmais68569
« on: February 21, 2018, 06:53:46 AM »
I have an AlphaPix controller that I want to upload to FPP, I have everything configured. When I go to my setup right click on the controller I get the following options:
E1.31 input definition or output
Which on should I use for this controller?
Then under E1.31 I get these options:
FPP Bridge
Falcon
 SanDevices
Under Output I get these options:
Falcon
Pixlite
SanDevice
J1SYS
Which would I use?
Thanks Mike
  • Kudos: 80
Re: Controller Upload Question
« Reply #1 on: February 22, 2018, 03:49:48 AM »
Are you trying to upload the E131 output config to send data to the Alphapix from FPP. If so use "FPP connect" under tools. In the "FTP" tab put in address the FPP and select "Upload controller configuration". Click "Upload"
If you are trying to upload the port configuration defined in layout screen of Xlights the Alphapix is not supported (nothing on setup tab of xlights).
Offline mmais68569
« Reply #2 on: February 22, 2018, 03:56:29 AM »
Thanks figured it out
Mike
