Author Topic: RS485 Diff Questions.... Advanced questions and possible tricks  (Read 790 times)
Offline jshults
The DIFF ports on Falcon boards are using RS485 2 Wire config.
I've used this in industrial and other situations and it's very useful and powerful.
Has anyone used one DIFF port to drive multiple receivers boards ? The protocol allows for chaining.
I wanted to use ONE DIFF output to drive identical devices at different locations via daisy chaining them.
This would save a lot of channels and ports and cabling.....
Has anyone run LONG length cables to the DIFF receivers? The SPEC says up to 4000 FT depending on data speed sent.
Comments >??>????
  • Kudos: 76
Re: RS485 Diff Questions.... Advanced questions and possible tricks
« Reply #1 on: March 02, 2018, 03:46:46 AM »
Comments >??>????
The chips in expansion boards are actually RS-422 compliant. You can connect approx. 10 devices in parallel. The max distance is about 300ft as the data is about 2Mbps.
Offline arw01
« Reply #2 on: March 02, 2018, 08:07:59 AM »
Do they make some sort of "hub" for this type of chaining?  Be curious for my 1-wire to have something more official.
Offline aknflyer
  • Kudos: 6
« Reply #3 on: March 02, 2018, 10:17:03 PM »
This is interesting. It might fit my application. How do you differentiate the boards? I dont recall an address for the boards.
  • Kudos: 76
« Reply #4 on: March 03, 2018, 01:57:31 AM »
You don't differentiate. The original poster wanted the receivers to mimic each other.
