Author Topic: 4 String DIff Rec Board question.  (Read 914 times)
Offline kjimkoski
« on: April 12, 2018, 09:28:45 PM »
I was going to buy a 4 String Diff Rec board to power a set of arches about 100 feet from my board. I was going to use strips to do this, but after i went to the store to get one, i noticed that is only supports 3 wire pixels and not the four. Ive seen pictures that it once supported 4 wire pixels. Does anyone got any advice of how to still do it with the current board? Or is there future plans to make it 4 wire again. ANy help is appreciated. Thanks
Offline algerdes
Re: 4 String DIff Rec Board question.
« Reply #1 on: April 12, 2018, 09:33:26 PM »
What pixels are you using that have 4 connectors?  (They are still out there, but getting scarce.)
Offline kjimkoski
« Reply #2 on: April 12, 2018, 09:34:27 PM »
pixel strips. not nodes.
Offline algerdes
« Reply #3 on: April 12, 2018, 09:35:30 PM »
WS2811?  WS2812?  WS2812b?
Offline kjimkoski
« Reply #4 on: April 12, 2018, 10:23:54 PM »
WS 2812, but after going back and looking at the picture of them on Ali Express, they might be three string, or so i hope
  • Kudos: 41
« Reply #5 on: April 12, 2018, 11:15:01 PM »
The the main controller board and the regular expansion boards support the clock signal for 4-wire pixels that need it, but the  DIFFERENTIAL receivers NEVER supported the 4-wire pixels.  Its uses 4-pin connectors to be physically consistent with the other boards, but it does not support the clock line.
They might be the new 2813 which has the extra "backup data" BI/BO wire.   The data is still WS2811 protocol and you can ignore the BI connection on the first pixel and only DO from controller to DI in the first pixel.  The backup data line is used between pixels in the string or between whole strings, but not between controller and 1st pixel
Image result for ws2813 led strip
« Last Edit: April 12, 2018, 11:23:22 PM by pixelpuppy »
Offline kjimkoski
« Reply #6 on: April 12, 2018, 11:50:52 PM »
I Swear IVe seen someone with a diff board that had the four wire setting printed onto the board.
  • Kudos: 76
« Reply #7 on: April 13, 2018, 12:11:39 AM »
Many did have the "clk" signal printed on the board by accident. The silk screening was copied from another controller and the "clk" term was not removed. The last few batches and all receivers going forward have been fixed.
