Author Topic: BBB + P10 Panel ( 4x2 ) + FPP v2.1 + Vixen Preview  (Read 261 times)
Offline parkej60
« on: October 19, 2018, 05:01:55 PM »
Hello,
I'm trying to figure out how to get it so that I can preview effects on my P10 Panels with Vixen. I'm able to export a sequence an upload it to Falcon Pi Player and it will play correctly on the panel, but it's going to be pretty time consuming if I have to upload every time I want to see how an effect looks. I've read about Bridge mode and was able to get Bridge mode to at "activate" pixels on the panel with FPP v1+ but now with FPP v2.1 I'm unable to get anything to show up when I switch the BBB to run in bridge mode.
I've tried configuring the E1.31 outputs only and tried just configuring the LED panel in the FPP but can't seem to get anything to work. Within Vixen I have the controller sending out over unicast and have it mapped correctly. I have the E1.31 outputs setup in FPP 2.1 setup as unicast as well. In any case I can't get the BBB running FPP v2.1 to seem to want to listen to the E1.31. traffic coming out of Vixen.
Thanks for your help in advance!
  • Kudos: 43
Re: BBB + P10 Panel ( 4x2 ) + FPP v2.1 + Vixen Preview
« Reply #1 on: October 19, 2018, 05:07:03 PM »
FPP V2.x added a Channel INPUTS screen.
Thats where you need to configure your E1.31 universes received in bridge mode
Offline parkej60
« Reply #2 on: October 19, 2018, 07:51:01 PM »
Great! Thank you Ill give this a try.
