Author Topic: What company can punch square holes in plastic.  (Read 796 times)
  • Kudos: 76
« on: June 12, 2014, 03:58:30 PM »
Does anyone know who punches the holes in the EtherDongle cases. My work needs to have some holes punched for a case we are using.
Offline pk
Re: What company can punch square holes in plastic.
« Reply #1 on: June 13, 2014, 02:30:30 PM »
Not sure who did the ED cases.  I have used this Denver company at a previous employer  http://www.wescolaser.com/
Offline dmcole
    • PacificaLights
« Reply #2 on: June 18, 2014, 07:42:13 PM »
RJ sends specs to the case manufacturer, who creates the cases with the holes in them. They aren't cut after market.
I can't remember the name of the case maker, but could root around and look it up if you want.
HTH.
\dmc
Offline keithtarpley
« Reply #3 on: June 20, 2014, 06:08:04 PM »
Greetings,,,
Polycase is one place we have used.  You can use their standard cases and then have various holes, covers, and/or graphics changed to suit.  You do have a one time charge for the set up, and then a charge per case for the holes.  More holes, more cost, etc.
Keith
  • Kudos: 76
« Reply #4 on: June 20, 2014, 06:39:33 PM »
Greetings,,,
Keith
Thanks Keith
