Author Topic: picap fpp install issues Pi3  (Read 344 times)
Offline Nikdyer
« on: November 07, 2018, 01:47:44 PM »
When I have Raspbian running, everything is smooth. No install issue. No problems whatsoever. I install FPP 1.5-1.8 (tried both) have same issue, black screen with FPP Login prompt. I have read in other posts that I need to access the Pi by IP. How can I connect the Pi to my WiFi when I am never prompted for WiFi information like when I use raspbian? Sorry but I am very frustrated. After failing install, I formatted my SD card and installed NOOBS just to verify my equipment works. Everything worked fine. Formatted and did clean install of FPP, black screen with Login prompt. Please help.
  • Kudos: 68
Re: picap fpp install issues Pi3
« Reply #1 on: November 07, 2018, 02:53:21 PM »
You have not stated what version of Pi you are using?  If you have a Pi3B+ you must be using v2.3.  Even if you are not using a Pi3B+ you should be using v2.3 and be sure to note that it uses a different installation procedure.
Offline Nikdyer
« Reply #2 on: November 07, 2018, 03:04:09 PM »
Jim, thanks for the reply!
 I just flashed v2.3 using etcher, plugged it into my pi and...... I was prompted for login. My already thinning hair is falling out in clumps with this issue today. I know that I am the problem, just cant figure out how.
Offline Nikdyer
« Reply #3 on: November 07, 2018, 03:19:27 PM »
Local. Not wifi. Got it.
