Author Topic: Differential receiver issue  (Read 442 times)
Offline jgrass
« on: November 15, 2018, 02:32:53 PM »
I'm using a differential receiver port out of the dmx port on my f16.  48 12v pixels per snowflake with no power injection and the flake connected to port 4 is flickering as you can see in the video (testing white ramp).  What could be causing?  I tried to add power to the end of that string but nothing changed
  • Kudos: 127
Re: Differential receiver issue
« Reply #1 on: November 15, 2018, 07:57:21 PM »
Does the flicker move with the string or stay on Port 4 only?
Offline jgrass
« Reply #2 on: November 16, 2018, 08:05:07 AM »
I just tried my 3rd network cable and that fixed the flickering issue.  Works fine now in test mode.  It's still not working when I run a sequence so I've got to figure out what's wrong with my settings now.  At least I have 5 days until I need to have everything running, uggh
