Ok I have a falcon 3 controller using xLights, all of my pixel strings run from left to right on my layout. However I have one set of icicles (Ray Wu 3,4,5) that would be a lot easier if I fed the signal and power from the right side of the string. Now I know I can set up xLights to start at the blue dot (right side) but this then requires me to actually put the start of the string on the right side of the layout. that would then have the icicles be 5,4,3 going left to right which would make them look different than all the other icicles.
Question is. can I leave the strands with the left to right orientation (3,4,5 first pixel on the left) use the green dot as the starting point in xLights however, put the power and signal into the tail end of the strands and setup up my Falcon 3 to reverse on this controller port? Is that how it would work? Any insights would be helpful. Thanks.
