Total Members: 17237
Latest: Routhhurwitz
New This Month: 1
Total Topics: 17328
Most Online Today: 282
Most Online Ever: 8375
Guests: 196
Total: 196
Bad data coming from 4 ports on F16V3
Started by K-State Fan, December 04, 2024, 05:27:21 AM
Quote from: K-State Fan on December 04, 2024, 05:27:21 AMJonD i assume that was you that was helping on Facebook.
I don't have a Facebook account so it was not me.  :)
K-State Fan
Quote from: K-State Fan on December 04, 2024, 06:31:51 AMI think I am an idiot.  Will verify when I get home form work tonight and report back.
Verified that I am an idiot.
You have to wire controller as designed not like i wish it was designed.
K-State Fan
You can set the serial output here. Last year i set to with one expansion even though i did not have a expansion card to get more port available.  This year I have extra ports so I left it as one expansion.
I vaguely remember that now.  When I set the F16v3 to "One Expansion + Serial Port Remotes" and upload the config to the controller, it changes the "Port Mode" on the F16v3 controller to "Main Board /w Two Expansions"
If you are not letting xLights autoconfig everything, you many need to manually change the port mode to "Main Board / w Two Expansions".  Xlights autoconfig sets them at port 33-36, but it might let you use them at 1-4 if you wanted to.
#19
For what is is worth...  when xLights is configured for "No Expansion + Serial Port Remotes" ... xLights autoconfig appears set the F16v3 Port Mode to "Main Board w/One Expansion, and change the serial ports to use 17-20.
when xLights is configured for "One Expansion + Serial Port Remotes" ... xLights autoconfig appears set the F16v3 Port Mode to "Main Board w/Two Expansions, and change the serial ports to use 33-36, but since I don't have an expansion card installed I get red errors on the controller because it is not detecting the expansion card.
Best guess, if you are configuring your controllers manually, that you need to set the port mode to "Main Board /w Two Expansions", and the the serial outputs to pixel data ports 33-36.
K-State Fan
#20
I will look into it more next year.  There is some reason I am doing like I am but do not remember.
It is just one thing I have to manually change. If I need to expand in the future I will get a differential expansion board (if still available)  and not use the serial port.
Can you update 3b+ to 9.5.3? by SCUBA
April 12, 2026, 01:50:41 PM
Moving Head Color by SCUBA
April 12, 2026, 11:00:42 AM
FPP 9.5 on Linux by coyoteray
April 11, 2026, 05:49:56 PM
VSA to FPP conversion program by Scaregroundspdx
April 02, 2026, 01:42:54 PM
Limitations of Matrix Display by conceptpl
March 27, 2026, 03:22:53 AM
F16V4 IP Address by MikeKrebs
March 23, 2026, 08:21:32 PM
Help troubleshooting by aaronhess
March 19, 2026, 09:21:24 AM
Can't seem to get my network connections right. by Poporacer
March 16, 2026, 11:21:39 AM
F16v3 Expansion bad resistors by 2Couyon
March 13, 2026, 04:03:59 PM
HUB75 P4 1/10 Matrix by k6ccc
March 13, 2026, 08:45:44 AM
