Is it possible to run DDP protocol from a remote Pi FPP to the F4V2? I am not seeing that option when I set up the controller in Xlights. If it is possible, what do I need to do to set it up?
Quote from: kenoman742 on December 13, 2021, 02:52:41 PMIs it possible to run DDP protocol from a remote Pi FPP to the F4V2?
Yes
Quote from: kenoman742 on December 13, 2021, 02:52:41 PMI am not seeing that option when I set up the controller in Xlights. If it is possible, what do I
Set up your controller for DDP. If your remote is wireless, then you might be using the FPP as a Proxy Host? If so, when you use FPP Connect, just set the UDP to Proxied on that FPP device.
Quote from: Poporacer on December 13, 2021, 04:08:10 PMSet up your controller for DDP. If your remote is wireless, then you might be using the FPP as a Proxy Host? If so, when you use FPP Connect, just set the UDP to Proxied on that FPP device.
I tried to set up using your instructions. First I set up the F4V2. Then went to Xlights and set up as shown on the attached screenshots (https://photos.app.goo.gl/NGF1am36Y7k8QkN16). Then used FPP Connect to set up outputs on the FPP Remote. The screenshots show what I got on the remote. This setup works but if I try to set the FPP on DDP it will not send any data to the tree at all. You will also notice that there is no DDP option in Xlights when setting up the F4V2 controller. Only E1.31 and ArtNet. Is there anything else I should try? Thank you very much for your help.
I guess the V2 doesn't support DDP, sorry
Thank you anyway!
