Falcon Player (FPP) => Falcon Player (FPP) => Topic started by: OliverG on June 08, 2022, 04:32:20 AM
Title: FPP6 Using a licence key on a custom bin
Post by: OliverG on June 08, 2022, 04:32:20 AM
I have a few of Alan's (Hanson Electronics) HE123 BBB Capes and just received my License Keys.
I have decided to create my own virtual eeprom (HE123-eeprom.bin) because I'm OCD and don't like the RGBCAPE123 port groupings. I used Adam's Eeprom Generator plugin and FPP6 seems to recognise it and pixels light up fine.
1. Will I be able to use the keys to sign the eeprom or will it throw an error as it is custom.
2. If I need to recreate the virtual eeprom can I re-sign it with the same keys (as long as it stays on the same BBB)
Cheers
Title: Re: FPP6 Using a licence key on a custom bin
Post by: CaptainMurdoch on June 08, 2022, 09:46:09 AM
You should be able to use the key to sign the custom EEPROM you generated.  I haven't tested signing with an EEPROM generated with Adam's plugin, but I don't know of any issues there would be.  If you run into a problem, let me know and I can look into it.  If it comes to that, put the .bin file up somewhere and PM me the URL and I can download and test.
Yes, you can resign on the same BBB, that shouldn't cause an issue.  I've been doing the same thing on a Pi during testing.
You could also use the new "generateEEPROM" script in /opt/fpp/scripts if you want to do it from the command line.  That is what I have used to generate all the Pi virtual EEPROMs in git.  I am working on adding a sample/template directory to the git repo which will make it easier to see what needs to be done to generate an EEPROM, but it sounds like you are a bit past that need already. :)  If you use the generateEEPROM script, you don't have to package up the zip/tar package inside the EEPROM, the script will handle that for you.
Post by: OliverG on June 08, 2022, 04:47:12 PM
Awesome Thanks, I will try the script as the way I did it was a painful and clunky as I had to work out the file structure and gzip/tar and after a dozen tries I'm not sure I remember which combination worked.  ;D
Post by: 3636lightshow on July 05, 2022, 01:18:58 PM
OliverG, Are you able to sing the HE123 with custom bin successfully, Please share steps I have HE123 MK I cannot update the license key.
Post by: CaptainMurdoch on July 19, 2022, 07:53:26 PM
I have a HE123-Mk2 that I have generated an EEPROM for.  I need to do a bit more testing and then can put the EEPROM in FPP's EEPROM list which will make it installable directly from the FPP v6 Cape Info screen.
Post by: dennismccreery on September 22, 2022, 05:08:52 PM
Quote from: CaptainMurdoch on July 19, 2022, 07:53:26 PMI have a HE123-Mk2 that I have generated an EEPROM for.  I need to do a bit more testing and then can put the EEPROM in FPP's EEPROM list which will make it installable directly from the FPP v6 Cape Info screen.
I don't see HE123 in the list of firmware on the latest (6.1) FPP.  Can you please point me to where I can get the file so I can sign my EEPROM?
Thanks,
Dennis the Menace
Post by: AAH on September 22, 2022, 07:45:50 PM
The process to get a he123 eeprom is to set a virtual eeprom to rgb123, save that, go to help/ cape info, go to eeprom upgrade, browse to the eeprom that you create using https://apps.mortonlights.com/he123-unsigned and then click upgrade.
I'm going to have to burn an image to all the he123 boards like I have to do on the rpi-mfc by the looks as the process is a complete shambles currently.
