The Lab (Technical Talk) => Protocols and File Formats => Topic started by: stlscott on November 13, 2018, 11:21:31 PM
Title: DMX, F16v2r, Stage Wash 7x 10w LED Moving head
Post by: stlscott on November 13, 2018, 11:21:31 PM
Ok let me just start by saying I feel stupid and frustrated.  This is my 3rd Christmas (2018) doing pixels.  I have no problem with the 5v strips nor the 12v nodes. This year I wanted to add a pair of moving-head lights (one being controlled via DMX and one just following the first one).  Anyway, I can't seem to get it to work for the life of me.  I took a standard network cable (10'), cut the end off of one end, opened up a 3-connector XLR blank to make a cable.  The network cable is standard and the orange pair are first.   I soldered Wh-Orange to Pin #3 (D+), both browns to Pin #1 (Ground), and Solid-orange to Pin #2 (D-).  I plugged the network cable into 2, 3, and 4th port on the F16v2R hoping to get one of them to work (never used any of them before).  No luck, it didn't matter which port I configured, it didn't affect the motion head light.  I setup the serial-port port #2 on the Falcon to be DMX, universe 48, starting channel #1.  I matched this in Xlights 2018.v42 and it just doesn't work.  I also made a terminator using a 100 ohm resister to pug into the other DMX port.  Again, nothing happens on XLIGHTS when I move the slides for the DMX device.  I made a NEW cable today thinking maybe I did something wrong or the network cable was bad... nope, didn't do anything.  I did put the falcon into test mode and the head would move up and down and only display red & green (even though it's an RGBW).
I know this is NOT supposed to be this difficult, what the heck am I doing wrong.
Title: Re: DMX, F16v2r, Stage Wash 7x 10w LED Moving head
Post by: ebrown19721972 on January 09, 2019, 10:27:06 AM
Quote from: stlscott on November 13, 2018, 11:21:31 PM
I am having the exact same issue. Does anyone have an answer to this question? I thought maybe there was something wrong with my controller (Falcon) so I tried another one but it does exactly as described above.
Post by: algerdes on January 10, 2019, 08:00:11 AM
Most DMX based "theater" equipment have an indicator on them showing that data is being received.  (All 48 of mine do, and they are from different manufacturers.)
Is there any indicator on the first MH that shows it is seeing data?
