Total Members: 15464
Latest: BroJam22
New This Month: 87
New This Week: 5
New Today: 5
Total Topics: 15541
Most Online Today: 107
Members: 4
Guests: 73
Total: 77
Getting nodes into Boscoyo matrix
Started by taintedsaint, December 10, 2018, 05:02:27 AM
taintedsaint
While current show is up and running, I am (like probably many others) working on items for next year.
Have two pieces of Boscoyo matrix panels, really pleased with sturdiness of them. Issue is getting nodes into the holes.
I understand holes are designed to hold the nodes tightly but compared to strips used for mega tree this is quite a fight.
I've tried some spare nodes from different manufacturers I had laying around to be sure its not a node issue but all the same.
While i have succesfully gotten most of them in one panel, using pixel pliers, I figured someone might have a trick to make it a bit easier.
Any ideas or tips from all you pros out there?
JonB256
Several people have used an electric heat gun (hair dryer on steroids) to warm the plastic for about 10 pixels at a time.
Definitely hard putting pixels into that when it is cold.
Emuney18
I did it last year and my only advice is have the plastic at least room temp. Get some good gloves. And push against something on the other side like a 1/2 pvc Tee or socket.  I can tell you that I had to swap a string in mine while on the roof and in full sun it was like pushing into butter. So full sun if that's an option or a good heat lamp.
taintedsaint
As a second hobby I restore vintage Cadillacs, have several I've done, and my particular skillset is interiors. So after using heat to stretch every material imaginable it is truly embarassing that I didn't think about a heat gun. Not like I don't have 3 of them in the shop.
It was at room temp but obviously needed a bit more.
Thanks for the input guys, I knew I couldn't be the only one struggling.
;D
Todd
I took a 3/4" board and drilled a 5/8" hole in it at the edge and cut it out to form a U. lay the matrix or Boysco strips on top and push the nodes in. Made it real easy to push the nodes into the holes and didn't kill the fingers.
Todd L.
Kimberly, WI
Falcon F16V3,F48, Kulp 32A-B, FPP, X-Lights, LOR, Pi 3B
