Total Members: 15464
Latest: BroJam22
New This Month: 87
New This Week: 5
New Today: 5
Total Topics: 15538
Most Online Today: 107
Members: 10
Guests: 69
Total: 79
Orange Pi's
Started by AAH, February 18, 2022, 03:48:02 AM
AAH
Just wondering who has played around with getting FPP onto an Orange Pi and if so what version/s FPP, what variety of Orange Pi and was there any limits on using with pixel outputs, video output, audio output or anything else?
With Raspberry Pi's becoming next to impossible to source due to shortages due to covid I'm looking at something to use that is actually in stock and not expected in December 2022 like the Pi3B+ is.
FPP should install on it fairly easily, but I'm not sure how useful it would be.   You wouldn't be able to drive any pixels from it directly.   We MAY be able to support using the SPI pins to drive some pixels, but those pins are different than the pwm pins so existing hat's wouldn't work.   The new DPI stuff wouldn't be usable as the Orange Pi doesn't have a mux for it on the pins.      Video would likely work, but be software decoded so likely limited in resolution.
Sounds like a candidate for a Master in a Master / Slave configuration - unless I'm missing something...
If you can run Debian 10 (Buster) on something, you have a good chance of FPP working via FPP_Install.sh as a Master or Remote with at least the ability to drive network based channel outputs.
I haven't used any of these recently, but over the years, I have run FPP on the following:
Orange Pi Zero
Pine64
ODROID-C1
NextThing C.H.I.P.
AtomicPi (x86 based)
PogoPlug (I ran FPP on this my first year after I decided to use my only Pi for Asterisk)
The problem I find with most of these is that they aren't supported anywhere near as well as the Pi and BeagleBone and they aren't as standard.  OS upgrades take longer to come out if they ever do, some hardware require vendor-specific patches or OS installs to get working, and some companies just fall by the way side like NextThing which went belly-up.  For kicks recently, I pulled out a C.H.I.P. and put Debian Jessie on it and then did an in-place upgrade to Buster, so it should be able to run FPP v5.x still, but with no direct pixel support and no wired Ethernet, it isn't of much use.  It does have a RGB666 DPI interface on the GPIO outputs, but I don't know if that would support the custom timing we'd need to drive pixels using the DPIPixels output.
djulien
Quote from: CaptainMurdoch on February 18, 2022, 03:17:44 PMIt does have a RGB666 DPI interface on the GPIO outputs, but I don't know if that would support the custom timing we'd need to drive pixels using the DPIPixels output.
The vga666 overlay is very similar to the dpi18 overlay.  They both control which pins are set for DPI, just some differences in which pins are used.  The timing is all handled by the GPU.
I read that the GPU chip is different, so the GPU firmware would also be different.  However, the processing load that DPI places on the RPi GPU is quite low (FPP only uses a 2.4MHz pixel clock for DPI), so the Orange Pi GPU firmware would need to be very inefficient in order not to be able to handle the timing.
Quote from: djulien on February 19, 2022, 08:44:09 PMI read that the GPU chip is different, so the GPU firmware would also be different.  However, the processing load that DPI places on the RPi GPU is quite low (FPP only uses a 2.4MHz pixel clock for DPI), so the Orange Pi GPU firmware would need to be very inefficient in order not to be able to handle the timing.
It's not really a question of whether it can handle the workload, it's a question of whether we can configure the proper WS281x timing on other SBC's DPI output.  Some don't have the configurability that the Pi's do or they may but documentation is lacking.  This is one of the reasons we have stuck with supporting just the Pi and BeagleBone, because of the level of community support and documentation other boards have.
What is the second best way to get rid of pixel gap errors? by k6ccc
Today at 11:10:26 AM
1st attempt success by ctmal
Today at 10:13:02 AM
Today at 10:08:21 AM
Today at 12:12:07 AM
