Total Members: 15300
Latest: lstewartff
New This Month: 3
Total Topics: 15247
Most Online Today: 86
Members: 4
Guests: 45
Total: 49
Volume control command to remote player via BigButtons
Started by greggsuter, August 27, 2022, 05:41:17 PM
greggsuter
I seem to have an issue with remotely controlling the volume of my remote player through Big Buttons.  None of the volume adjust/set/decrease/increase commands seem to work when I launch them through Big Buttons, but do work if I run the FPP command from the bottom drop down list, or if I run it from a scheduler event.
This only seems to affect the command going from the main player to the remote.  Any volume command works from Big Buttons if it is controlling that local player (not multicast).
Both players are connected to the same wired network, and are able to talk to each other, and the remote player responds and plays when I load a playlist on the main player, so they are synching.
As of this post, both are running the latest version of FPP 6:
FPP v6.0.2-8-g8bc1f372
Branch: v6.0
I also have a 3rd player I use for testing, and it is connected to the same WiFi network as the other two, and behaves the same...I can remotely control its volume if I run the fpp command from the drop down menu on the bottom of the page, but will not work with the same command through Big Buttons.
I also checked to see if the plugins I have installed are the latest version, and they are.
I would like to be able to manually control the volumes of the remote player, even though I can automate the volume levels during a playlist or scheduler event.
Attached is my apache2 error log (renamed to a .txt extension to allow upload), and I deleted all of the lines except the ones for today.  The error I seem to see regarding the Big Buttons issue says there's an issue with line 46 in the config.php file in the bigbuttons plugin directory.  I opened that file to see what line 46 says, which is:
<input type='text' class="buttonTitle" placeholder="Name Your Button" id='button_TPL_Title'maxlength='80'  value='<?=$description;?>'></input>
I also LOVE the brightness fade feature, and have successfully tested it through Big Buttons.  I have certain times of the day during a playlist where it is necessary to dim the lights without restarting the playlist or sequence, and before the fade feature was available, they just immediately dimmed to a lower level, rather than gradually dimming to that level, which will make it appear more attractive.
Are you on the latest version of the plugin and is the Multisync checkbox showing when you setup the command in the Big Buttons config page?  If it isn't showing, check for plugin updates, there was a bug fixed earlier this year which fixed and issue with the plugin allowing the commands to be sent to remote FPP instances.
greggsuter
Updated bigbuttons (then verified all updates are installed) and also updated to FPP version 6.0.2-9gf245c06d branch 6.0.  Both players are running the same version of FPP, and are connected to the same wired network.  I also tried different settings in the multisync setting page, but still the same issue.
When I have multisync checked in the big buttons command and using the ip address of the remote player, it only adjusts the volume of the main player, even though it's ip address isn't entered in the multisync host box.
I can adjust the volume using the FPP command, and running the same command as I would through big buttons.
I can also run the same command as a command preset (like when FPP starts), and it adjusts the volume to the value I specify, so it seems to be something to do with the bigbuttons plugin.
Quote from: greggsuter on September 08, 2022, 11:41:27 PMWhen I have multisync checked in the big buttons command and using the ip address of the remote player, it only adjusts the volume of the main player, even though it's ip address isn't entered in the multisync host box.
This is a bug and is being fixed
It should be fixed now. Update the plugin and let us know if it is working.
Projector video for just one video source by Poporacer
Today at 09:21:09 PM
Today at 05:06:52 PM
Today at 04:18:23 PM
Today at 01:39:26 PM
Today at 01:26:22 PM
Today at 05:34:34 AM
October 01, 2022, 10:24:15 PM
October 01, 2022, 08:31:43 PM
October 01, 2022, 08:57:49 AM
October 01, 2022, 07:49:10 AM
