Total Members: 15300
Latest: lstewartff
New This Month: 3
Total Topics: 15247
Most Online Today: 86
Members: 3
Guests: 32
Total: 35
trouble getting bbb to boot
Started by bert-nc, September 13, 2022, 07:00:28 PM
bert-nc
I received a new bbb from wired watts to replace one that I damaged.
From the labeling i thought sd card had been formatted, inserted card, powered up bbb by usb tethering.
powered led lit, other leds flashing. However after waiting a minute or more, typing 192.168.7.2 into browser (firefox) try to connect, unsuccessful.
reflashed card, same process as above, no success
tried usb tethering cable sent by wired watts, no success
placed bbb on K8-B cape, powered up, using 12 volt power supply, oled did not light up
if i type in 192.168.7.2 with usb tethering cable hooked to computer i get a web page (9 cloud) stating i need to upgrade my software, with instructions above my pay grade
held the s2 button once for 5 seconds with no success
i even placed the sd card from the damaged bbb into new bbb, with the same results
followed trouble shooting guide with no solution to my problem
completely stumped, any ideas
bert-nc
however
Kensington Graves
#1
Quote from: bert-nc on September 13, 2022, 07:00:28 PMif i type in 192.168.7.2 with usb tethering cable hooked to computer i get a web page (9 cloud) stating i need to upgrade my software, with instructions above my pay grade
Check your router's IP address range.  My guess would be that your router is configured for the xxx.xxx.7.xxx subnet, so your computer is being sent on a wild goose chase when it tries to reach that address.
When I set up a BBB, I typically do not tether.  I plug a network cable into the BBB and the router, and power the BBB via a 5v power supply.  Hold down S2 while you apply power—very important as this is often overlooked.  It's a bit awkward to hold S2 and inset the power prong, but that's what you need to do.  You need to hold the S2 button until the lights start flashing, which might take longer than 5 seconds.  Then I go looking for the BBB on the "attached devices" list on the router.  You can us "FPP" or "fpp.local" if you don't have any other FPP devices on the network and the BBB is hardwired to the router.  This assumes that you have the SD card installed, too.
The BBB comes with an OS installed on its onboard flash memory, and it is the default boot device.  Holding down S2 while applying power forces the BBB to boot from the SD card.  Pressing S2 after power is applied is too late and does nothing.  You only need to do this once if an SD card containing a FPP image is installed.
And make sure the SD card is formatted and an image is written to the card using Etcher, Win32 Disk Imager, baleenaEtcher, or ApplePi Baker.
bert-nc
A couple other things.  There is nothing like having some one nearby that you can visit and talk to for help.  Put your city and state in the signature of your profile.
For the fastest help go to the zoom room.
Quote from: bert-nc on September 13, 2022, 07:00:28 PMFrom the labeling i thought sd card had been formatted, inserted card, powered up bbb by usb tethering.
With the onslaught of USB powered/Charging devices, there are a TON of USB cables that are Power only. Make sure the cable supports data.
Quote from: bert-nc on September 13, 2022, 07:00:28 PMpowered led lit, other leds flashing. However after waiting a minute or more, typing 192.168.7.2 into browser (firefox) try to connect, unsuccessful.
Do you have an OLED screen on this device? What does it display?
I would try to re-image the SD card, sounds like you might have a corrupt image
bert-nc
thanks for the suggestions
i will have to pick-up or order a 5v power supply to try the router recommendation
the cable I used was one that I used on the previous bbb, so I know it does power and data
also Wired Watts sent a cable with the bbb
the oled screen I mentioned was the one on the k8-b cape, and it never lit up at all
I know someone who lives next door to my son you uses beaglebones in his display, so i might check with his neighbor next time I visit my son. They are only about 45 minutes away
The zoom room is also a great idea, but will try suggestions mentioned here first.
Hopefully this weekend I can try out some of these ideas
will not be long till some of you will start putting up your display
bert-nc
Projector video for just one video source by Poporacer
Today at 09:21:09 PM
Today at 05:06:52 PM
Today at 04:18:23 PM
Today at 01:39:26 PM
Today at 01:26:22 PM
Today at 05:34:34 AM
October 01, 2022, 10:24:15 PM
October 01, 2022, 08:31:43 PM
October 01, 2022, 08:57:49 AM
October 01, 2022, 07:49:10 AM
