Total Members: 15292
Latest: Rroark
New This Month: 38
New This Week: 7
Total Topics: 15234
Most Online Today: 74
Members: 3
Guests: 40
Total: 43
No signs of life, help
Started by projectortoph, September 23, 2022, 11:18:17 AM
projectortoph
Hi everyone,
I have a F48 v1.01 that runs my whole light show. It has been powered off since January until yesterday when I tried powering it on and got nothing, no OLED and no power LED. I verified my 5v power is working but still nothing. The F48 is mounted in a CG-1500 box on the wall of my garage year around but it is not powered. Any ideas for troubleshooting? Thank you.
Per manual "A 5V with a 3A minimum is required to power the controller. Use either the barrel connector OR the V2 Power Connector to power the board, NOT BOTH. This power supply only powers the controller, it does not provide any power to the pixels themselves. "
Assuming you have tried another outlet, and not something as simple as GCFI that has tripped.  You can make sure the power wires did not corrode from humidly or short out somewhere,  If your not getting any signs of life, sounds like the board could have went bad.
fauxton
Did you verify that the 5/12v switch or jumper is in place?  I'm not familiar with each version but I know most of them have it.
projectortoph
Thanks for the reply JonD. I have verified power and tried a brand-new Meanwell 5v 60A power supply. I'm only talking about the F48 board.
fauxton, the F48 controller only accepts 5v.
Quote from: projectortoph on September 23, 2022, 01:47:36 PMI have verified power and tried a brand-new Meanwell 5v 60A power supply.
The older smart receivers require 5.3 volts to run.  If you are using a meanwell power supply, you might crank up the volts to 5.3 and see if anything lights up.  If not turn it back down to 5.0.  If that was the issue, it would have probably showed itself last year though.
projectortoph
Thanks JonD, but the problem isn't with the receivers and the Meanwell power supply is outputing 5.3V.
I have emailed David Pitts and went through some basic troubleshooting but ultimately I will be sending it to him to look at.
The F48 manual stated 5v minimum, but it was for an older board revision.  You mentioned 5v, so if you were at 5.0, I thought there might a long shot that 5.3 might get you over the hump.  Some of the new smart receivers require 5.3 volts and was not sure if the newer F48 version did as well.  Glad your getting to the bottom of it.
K40 PB not transmitting music by Poporacer
Today at 07:31:17 PM
Using GPIO inputs for multiple uses? by Poporacer
Today at 07:27:10 PM
Micro-SD by Poporacer
Today at 09:46:41 AM
New K4-PB wifi problems by bossier17
Today at 08:38:32 AM
OrangePi 3 LTS wifi by ctmal
September 27, 2022, 04:57:48 PM
Pi Top on sale by JonB256
September 27, 2022, 04:44:05 PM
WiFi RGB Light Bulbs (Wiz or phillips) by smoothsa
September 27, 2022, 02:42:13 PM
Email Setup 6.1 by jem5136
September 27, 2022, 08:16:21 AM
Sequencing timing... by JonB256
September 27, 2022, 06:47:30 AM
K16a-b FPP setup by Dunkelzahn
September 26, 2022, 10:59:22 PM
