Total Members: 15506
Latest: rbatch
New This Month: 14
New This Week: 6
New Today: 6
Total Topics: 15603
Most Online Today: 61
Members: 3
Guests: 29
Total: 32
How to use Resolume Arena Video output (Artnet) with Falcon V2 (E1.31)?
Started by b33son, April 16, 2016, 09:20:38 AM
b33son
Is there a software or a hardware solution to converting Artnet to E1.31 that works well? I have both an e682 and a Falcon and I'd like to be able to use my Falcon as well with Resolume Arena which can only output Artnet.
Also, does anyone know if "DMX PRO" means Artnet in Vixen 3? I've always used E1.31 in the past so Artnet is all new to me.
I don't know what Resolume Arena is so I can't answer that question.  As for DMX PRO, that is for the DMX dongle type that you are driving.  There are basically two types of DMX dongles that are used in our lighting world.  One is the open dongle and that dongle is really nothing more than a protocol converter.  This dongle requires the input device to set the timing and create the data packets.  All it really does is put the data stream in the wire.  The PRO dongle OTOH, does all of the heavy lifting.  All it requires from the input device is a stream of channel values and it creates the data packets, sets the timing, and puts it on the wire.  Why do you need to output Artnet and why do you need to convert it to E1.31?
neilric99
DMX PRO in Vixen most likely refers to a USB interface like the Enttec pro. this contains electronics to handle the dmx framing rather than your pc having the handle it.
I think the F16V2 only supports E1.31 for both the bridge and outputs in the current release.
Resolume Arena is a media server and can drive a led wall over the ethernet and Output and Receive DMX via Artnet and Enttec USB devices.
So if your sequencer lets you output Artnet you can drive Resolume Arena using the dmx effects (same goes from driving Madrix). I remember talking about adding open DLA to FPP to support this last year, not sure how far that got though.
Quote from: neilric99 on April 17, 2016, 10:45:26 PM
FPP supports using OLA to send ArtNet, but FPP does not currently support OLA input to receive Artnet.  This is on my TODO list, but it is below a bunch of other items so it probably won't happen this year.
b33son
Quote from: tbone321 on April 17, 2016, 08:23:43 PMWhy do you need to output Artnet and why do you need to convert it to E1.31?
Resolume Arena is only able to output Artnet. There's no support for E1.31, so as of right now, I can only use Artnet on the e682 and I can't send at all to my Falcon V2.
Quote from: CaptainMurdoch on April 18, 2016, 12:51:35 PM
It would be great to get support for input DMX/Artnet with FPP. I'm planning to use Raspberry Pi/Pixel Hat for wireless receivers for LEDs on performers/dancers.
I currently have a large LED video display. That runs using video output from Resolume Arena 5. I'm now adding LEDs to the truss and certain elements around the LED Video display. I've successfully gotten Resolume Arena to output Artnet/DMX to the e682. Works really great. However, I wanted to add the ability to overlay some sequences. This could be done from Vixen, but only if I can get DMX/Artnet to output correctly since I can't switch to E1.31 on the board and still communicate with Resolume.
Based on your input, I believe Open DMX is what I'm supposed to use, but oddly it's not working.
Here's what I'm building...
b33son
I'm still looking for a way to convert Artnet into E1.31. If anyone has any ideas, it'd be greatly appreciated! Thank you!
David Pitts
I will add Artnet to F16V2. I need to finish shipping them than I will look into it. I do not foresee it being to hard to implement a subset of the protocol to allow reception of data.
Mac Hosehead
Quote from: b33son on April 26, 2016, 07:53:55 PM
OLA can convert Artnet to E1.31 on a universe basis. I am told the limit to this is 4 universes which is a limitation of Artnet inputs.
http://opendmx.net/index.php/Open_Lighting_Architecture
loading playlist by Poporacer
Today at 08:52:57 AM
Linking FPP Run Command to a Button by Poporacer
Today at 08:50:40 AM
Needs Repair by boostedmopars
Today at 08:38:27 AM
Today at 07:40:14 AM
Today at 05:59:19 AM
