Total Members: 15505
Latest: jduncc
New This Month: 13
New This Week: 5
New Today: 5
Total Topics: 15602
Most Online Today: 61
Guests: 25
Total: 26
µSC Progress and Projected Timeline for Co-op / Delivery (Updated 6/4/14)
Started by corey872, March 25, 2014, 06:52:15 PM
smeighan
All of the controllers (e682, j1sys, falcon-16) send data to the lights as a zero to 5v signal. The maximum distance to your first light is 10-30'. A ssc or usc sends data as -12v to +12v. This 24v signal can go 100-300' to the first light. I think the j1sys board has an option to change the 5v signal into the 24v signal for $20 per string. This new usc sets some new ground. No other receiver is this small, this full featured, this tested. I look forward to them. I love the micro reed option. Now I am in the back yard assembling my arches, hold a magnet near the usc and a test pattern starts.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Sean
smeighan
Quote from: David Pitts (dpitts) on March 27, 2014, 08:11:38 PM
Quote from: bagley2000 on March 27, 2014, 08:03:14 PM
these would work on a DLA 16 Port Active Hub?
Yes.
Quote from: smeighan on April 05, 2014, 07:39:00 AM
All of the controllers (e682, j1sys, falcon-16) send data to the lights as a zero to 5v signal. The maximum distance to your first light is 10-30'. A ssc or usc sends data as -12v to +12v. This 24v signal can go 100-300' to the first light. I think the j1sys board has an option to change the 5v signal into the 24v signal for $20 per string. This new usc sets some new ground. No other receiver is this small, this full featured, this tested. I look forwafd to them. I love the micro reed option. Now I am in the back yard assembling my arches, hold a magnet near the usc and a test pattern starts.
Sean
ricopico
Sean, so using a magnet near the controller starts a test pattern?
corey872
Yes - as detailed in the demo video.
Dave informs me we shouldn't have to cycle power to enter test mode, so I will work on that and see what I can come up with.
Corey
arw01
Quote from: corey872 on April 16, 2014, 05:20:55 PM
+1 on figuring that out.  Be so nice to plug them in, put the magnet close, know they have power and the lights work and move one, then it's just a config issue for channels if they are not working!
Alan
corey872
Corey
smeighan
Sean
JonB256
I knew the Falcon 16 worked that way. Glad it wasn't a difficult change.
sent from my Galaxy Note
MyKroFt
For the Falcon boards is there a reed switch small enough to replace the 2 pin header?
Like vertical or something?
Tony
corey872
Dave would know better on all the spacing, but the closest fit may be something like a Littlefuse model 59165-1-U-00-A.  If it's the standard .100" pitch header, you would probably have to bend one lead of the reed switch around and mount it vertically in the space... much like you'd mount a vertical resistor.  But the body of this switch is only 0.095" square, so it would fit the .100" hole spacing fine.
Downside is, these are a bit pricey at ~$1.92 each and dropping to $1.10 ea at quantities of 100.
Corey
Today at 07:40:14 AM
Today at 06:52:05 AM
Today at 05:59:19 AM
loading playlist by rangerdan
December 03, 2022, 11:54:31 PM
Sequence freeze by jnealand
December 03, 2022, 02:51:04 PM
