Total Members: 15464
Latest: BroJam22
New This Month: 87
New This Week: 5
New Today: 5
Total Topics: 15538
Most Online Today: 107
Members: 3
Guests: 85
Total: 88
For those setting up a Beaglebone Black
Started by charleskerr, June 10, 2014, 02:34:00 PM
charleskerr
If you are working to get a Debian environment on your Beaglebone black for basic ARM and PRU development  these are the steps that worked for me.  It does assume some working knowledge of linux command line
BeagleBone setup for Debian
Helpful links:
http://eewiki.net/display/linuxonarm/BeagleBone+Black
http://tara.mmto.org/computers/beagle/pru/devel/git_devel.html
http://mythopoeic.org/BBB-PRU/am335xPruReferenceGuide.pdf
http://mythopoeic.org/bbb-pru-minimal/
NOTE:
   The username/password will be debian/temppwd
Obtain the latest image from here:
http://elinux.org/BeagleBoardDebian#Flasher
After flashed do the following:
   apt-get update
   apt-get dist-upgrade
   apt-get install build-essential
   apt-get install vim
   apt-get install ca-certificates
We need to the device tree compiler ("dtc") for our overlays.
    apt-get install device-tree-compiler
However, this is not always up to date.  To get the latest, we can do the following:
   wget -c https://raw.github.com/RobertCNelson/tools/master/pkgs/dtc.sh
chmod a+x dtc.sh
./dtc.sh
When complete, you can delete the git directory it makes with the following:
rm -rf git/
//    The Following is dependent on what version of the image you.  And your capes.  The pins you want to expose.
//   Bottom line is you don't get the PRU enabled at initial start.  If you want to have it on boot, and you know the default dtbo file (they are located in /lib/firmware)
then you would probably do something like the following
We now have the basic compilers and libraries installed.  We are ready to move on to setting up the PRU enviroment
edit the /boot/uboot/uEnv.txt file
     cape_enable=capemgr.enable_partno=BB-BONE-PRU-01
This may not have the pins configure how you want, so you should look at the dts (the etc you installed can convert the dtbo back to a dts)
For an useful environment variable, add the following to /etc/profile
   export SLOTS=/sys/devices/bone_capemgr.*/slots
To verify all has gone well so far, reboot the system
     reboot
If you want to see the slots enabled on your system, do a:
   cat $SLOTS
You should get something like this:
0: 54:PF---
1: 55:PF---
2: 56:PF---
3: 57:PF---
4: ff:P-O-L Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G
5: ff:P-O-- Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI
6: ff:P-O-L Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN
7: ff:P-O-L Override Board Name,00A0,Override Manuf,BB-BONE-AUDI-02
The "L" in the P-O-L means the item is enabled.  Note the HDMI are not enabled.
// This is optional.  However, if you are going to run PRU code, you will need the libraries added at the end
Setting up the PRU build environment.
Get the source tree:
         git clone https://github.com/beagleboard/am335x_pru_package.git
         cd am335x_pru_package
         cd pru_sw/app_loader/interface/
         CROSS_COMPILE= make (note the space between the = and the command)
         cd ../lib/
One should see the following: libprussdrv.a  libprussdrvd.a  libprussdrvd.so   libprussdrv.so
Copy these to the /usr/lib
         cp * /usr/lib
         ldconfig
Now change directory to
         cd ../../utils/pasm_source/
      source linuxbuild
      cd ..
      cp pasm /usr/bin
      chmod a+x /usr/bin/pasm
      cd ~/am335x_pru_package/pru_sw/app_loader/include
      mkdir /usr/include/pruss
      cp *.h /usr/include/pruss/
Setting up the ntp server
       apt-get install ntp
       dpkg-reconfigure tzdata    << this setups timezone
To get your sd card to mount, add the following to /etc/fstab
   /dev/mmcblk0p1       /media/microsd     auto    defaults  0       0
create a directory for the mount point
   mkdir /media/microsd
In addition, to ensure you can boot with a SD card present, have the following file (uEnv.txt) on the sd card
mmcdev=1
bootpart=1:2
mmcroot=/dev/mmcblk1p2 ro
optargs=quiet
One is never too old to learn
David Pitts
Great information Charles. This will be great to have for development of the Beagle code. Thanks for the post.
Yes, thanks.  It will definitely save me some leg work when I get around to playing with one.
JerryPlak
Yes Great information Charles, it be fun to test and getting around to playing with one  8)
Jerry Plak
What is the second best way to get rid of pixel gap errors? by JonD
Today at 10:35:44 AM
1st attempt success by ctmal
Today at 10:13:02 AM
Today at 10:08:21 AM
Today at 12:12:07 AM
