Total Members: 15504
Latest: Nicolarockarola
New This Month: 12
New Today: 4
Total Topics: 15599
Most Online Today: 49
Members: 3
Guests: 25
Total: 28
Smart Differential Expansion No Data on Port 1
Started by Davis80, December 01, 2021, 08:04:08 PM
Davis80
I've got a smart receiver that is only getting 3 data lights to light and port 1 will not put out the test pattern to a string connected to it through the controller test page.  Port 1 functions normally while operating test mode from the receiver.
I've tried new cables and swapped cables around and one of the smart receivers works great, just nothing for port 1 on one of them.
Any ideas?
rudybuddy
You need to explain your setup in more detail. I'm assuming you have 2 smart receivers connected to your controller. Are receivers setup in Normal mode and independent from each other or are they chained together as receiver (A) and receiver (B)?
Davis80
I have 2 smart receivers with the DIP switches set appropriately for A and B with B having the terminators set to on.
They are both attached to my K16 AB. If I attach receiver B first in the string, all 4 data LEDs light and receiver A 2nd, only 3 data LEDs light.
I switched things over to A first B second and behavior is the same. All 4 data LEDs light on receiver B and only 3 data LEDs on receiver A.
rudybuddy
Take receiver B and set the DIPS to make it A and terminate. Connect it to the controller and check the results.
I would take a close look at the cable you are using to connect the two receivers together.  If reversing the positions of the two receivers is causing the change you are describing, that is one of the two primary causes.  The other could be the terminator switches but that is uncommon.  Make sure that BOTH sets of terminator switches on the last receiver are set in the same direction and try again with a different cable between the two receivers.
algerdes
The description you provide says you have the terminators on for the "B" unit, yet it is first in the string.  The terminators should be on for the last unit (no matter what designation) in the physical string.
Having termination on at the first unit means the signal will be less than desirable to the second unit as the first unit has placed a resistor across all ports.
BRP Voting Plugin - Allow others to vote for your songs! by Barkers Random Projects
December 03, 2022, 11:55:24 PM
loading playlist by rangerdan
December 03, 2022, 11:54:31 PM
December 03, 2022, 09:41:41 PM
Remote Pi connection issues by JonD
December 03, 2022, 08:51:55 PM
FPP not releasing control to WLED when idle by cabrio
December 03, 2022, 08:24:43 PM
December 03, 2022, 03:45:54 PM
Sequence freeze by jnealand
December 03, 2022, 02:51:04 PM
December 03, 2022, 02:46:23 PM
December 03, 2022, 02:38:26 PM
December 03, 2022, 12:04:54 PM
