Total Members: 15463
Latest: Lwarnell01
New This Month: 86
New Today: 4
Total Topics: 15537
Most Online Today: 90
Members: 5
Guests: 46
Total: 51
Injecting power from different power supply
Started by jeff.ott, January 13, 2018, 01:09:25 AM
jeff.ott
Hey,  how is everyone isolating the + when injecting power from a separate PS from the controller and using the "T"'s that are available from Ray and Paul (or others)  do you cut off the + lug on the "T" gong back to the controller keeping the signal and - wires or do you make your own "T".  Not sure how to handle this efficiently.  Thanks for any help.
Jeff
vipersinu2
I run bell wire from the controller's data/ground to the prop. Then power Inject as needed. The grounds are all common. It ok for the ground to make it back to the controller. Do not let the positive of your powers supplies make it back to the controller.
JonB256
As far as isolating the V+ (by cutting or somehow disconnecting) between power injection points.
If it is the same power supply at different injection points, then none of this applies.
But if it is one or two or three totally different supplies, then you should definitely/absolutely connect their V- (dc grounds)
Where I differ with some is that, if you have many pixels (let's say 50+) between injection points, I don't disconnect or cut the V+
The amount of wire length and resistance and voltage drop between the injection points, even when pixels are dark, and certainly when running, will serve to stabilize any voltage swings that we are concerned about.
My roof snowflake array uses 3 350watt supplies. I inject between every other snowflake (48 pixels each). With pixels dark and all connected, I adjusted all 3 to the same 11.5vdc. I used Ray Wu "T" injectors between the snowflakes. I like them because they have 2 wire input (V+ and V-) but 3 wire pass-through so there is no "dangling" data wire going out of the T that can degrade the data signal.
CarterM
Make sure when you do this you use the proper sized ground. The ground wire can and will carry as much current on it as the positive does. Don't skimp on the wire gauge when you do this.
jeff.ott
Thanks for the feedback everyone.  I'm still not sure how to actually create a T that allows data and negative to pass through but isolates the positive from going through the T. I may check with Ray and see if he can make an isolated T that doesn't pass the + through the T.
vipersinu2
Can't you just take the positive wire out of the Phoenix connector at the controller and put a wire nut on to cap wire?
What is the second best way to get rid of pixel gap errors? by dkulp
Today at 08:33:03 AM
Today at 12:12:07 AM
Daisy Chain PSU by schbrownie
