LATEST RELEASE:  FPP 9.3 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/9.3
Total Members: 17167
Latest: Marsvinrex
New This Month: 21
New Today: 4
Total Topics: 17246
Most Online Today: 330
Guests: 63
Total: 64
Advice welcome
Started by Kirbcheck, October 11, 2025, 10:40:29 PM
Kirbcheck
Greetings from Nebraska.
I'm looking to get started with basic LEDs mounted to the roofline and gutters this year, with the opportunity to grow slowly over time.
This year to start, I just want to mount permanent LEDs as noted in Yellow on this picture, and a control box inside my garage at one of the red circles.
My plan is to permanently mount aluminum rails where designated in yellow, with 2813 LED strips inside (60 Pixels/Meter) using a 20v power supply and 20v to 5v stepdown converters. Total Linear distance would be 20 meters.
I have a few older Rasberry PI's sitting around (B+, 2B, 3B, Zero). I'd like to use one of these dedicated to the project.
As I understand it, I also need a pixel controller. This is the part where I'm struggling to find what I need. Seems there are limited options with multiple ports that offer 2 data wires, unless I'm willing to drop a couple hundred. I like the option of 4 wire strips as a level of protection in the event I have a pixel burn up for some reason.
It seems that 20 meters of the 2813's with 60 LED's a meter is just over 1200 pixels to control. So I would need a controller with at least 2 ports. and If I use the 2813's I need at least 2 ports that support dual data lines. Correct? Is there a pi hat capable I'm not finding? I would I need to shell out $250 for a bigger board like the Falcon 16?
Open to suggestions on everything I'm throwing out. If there are resources you feel I've missed reading or watching, please share. I'm trying to take in as much as I can.
Thanks.
Yffej
I just added RGBW puck lights. For a controller, I chose a Dragon differential receiver from Mattos. The reason I chose this is it contains two receivers in one housing and has 8 ports total. I have them located strategically where I can form a T that drives the pucks left and right, one off of each receiver. The remaining unused 6 outputs can be used for spinners, etc...
I use a K8B or a Genius controller to the for the differential transmitter. I have Raspberry Pi in the Genius controller.
Kulp K16 Max Network Setup by dkulp
December 07, 2025, 05:00:48 PM
SRx4 pixel count by Poporacer
December 07, 2025, 04:22:02 PM
Enable/disable schedule through API or button by MikeKrebs
December 07, 2025, 01:04:13 PM
Lynx Express reflash by zwiller
December 07, 2025, 11:56:04 AM
How to start a playlist in FPP using a Midi or OSC by nightowl
December 07, 2025, 10:47:37 AM
FPP Connect kicks off FPP Schedule by ukkeef
December 07, 2025, 03:12:20 AM
FPP SMTPE plugin by nightowl
December 07, 2025, 12:55:32 AM
Bad data on daisy chained SRX1-PSU by davidr236
December 06, 2025, 03:36:21 PM
Kulp K16A-B RJ45 differential receiver output pixel count specs? by aggieNick02
December 06, 2025, 11:20:02 AM
BRP Voting Plugin - Allow others to vote for your songs! by Barkers Random Projects
December 05, 2025, 09:33:10 PM
