LATEST RELEASE:  FPP 7.0 - Download from here - https://github.com/FalconChristmas/fpp/releases/tag/7.0
Total Members: 15931
Latest: pavit66767
New This Month: 0
Total Topics: 16009
Most Online Today: 140
Guests: 112
Total: 114
BBB48String: Could not read pin configuration for F8-B-EXP-32
Started by ctoddward, April 19, 2023, 10:09:13 PM
0 Members and 2 Guests are viewing this topic.
ctoddward
Kulp F8-B - preconfigured SD card.    New guy, I've had my controller for 2 days and already bricked it.
From xLights controller setup I set "Auto Upload Configuration" and then hit button "Upload Output".
FPP no longer working, getting error:
Abnormal Conditions - May Cause Poor Performance
BBBSerial: Could not read pin configuration for F8-B-EXP-32
Could not initialize output type BBB48String. Check logs for details.
Could not initialize output type BBBSerial. Check logs for details.
I believe xLights messed up my configuration within FPP.
The question is how to fix it?
How do I check logs?
Can i fix it or do i look at reimaging?
Quote from: ctoddward on April 19, 2023, 10:09:13 PMKulp F8-B - preconfigured SD card
Are you sure it is an F8-B? What does it say on the board itself? The F8's are an older version and since you are new, I have a feeling that you don't really have an F8?
Quote from: ctoddward on April 19, 2023, 10:09:13 PMFrom xLights controller setup I set "Auto Upload Configuration" and then hit button "Upload Output".
Auto Upload Configuration will upload your controller configuration when you click on the Output to lights in xLights, BUT most of the time you probably do not need to keep uploading your configurations. If you are going to manually upload your configurations (Recommended) then un-check the Auto Upload Configuration.
Quote from: ctoddward on April 19, 2023, 10:09:13 PMI believe xLights messed up my configuration within FPP.
xLights will only do what YOU tell it to do,
xLights probably didn't mess up your configuration, you told xLights to mess it up....LOL
You probably have the wrong controller type set in xLights...That is a common mistake that people make.
How about a screenshot of your Controller page in xLights? (a screenshot please and not a picture of your screen)
Quote from: ctoddward on April 19, 2023, 10:09:13 PMThe question is how to fix it?
Depending on what you actually broke, sometimes you can go to the Input/Output Settings>Channel Outputs and then go to the pixel strings tab and simply save your settings...
If that doesn't work, let us know, depending on the answers to the above questions, the path to recovery will be different.
Quote from: ctoddward on April 19, 2023, 10:09:13 PMHow do I check logs?
You might want to look at the FPP Manual...at this point it probably won't do you any good to look at the logs.
https://falconchristmas.github.io/FPP_Manual.pdf
Quote from: ctoddward on April 19, 2023, 10:09:13 PMCan i fix it or do i look at reimaging?
It can be fixed....Re-imaging might be quicker, but if you don't identify what caused the problem, you will be in the same boat....
Letting xLights manage your controllers is highly recommended!
bloojoop
If you actually have a K8-B and accidently configured xlights as F8-B and uploaded output, this will cause this message.  If that is all true, then just select the proper Kulp controller such as K8-B (or your actual controller) and upload output again and it should correct this issue.
--Ron A.
ctoddward
I feel pretty stupid.  I was doing configuring F8, but I have an K8.  But, so happy it is an easy fix.  thanks so much, you are the best.
Quote from: ctoddward on April 20, 2023, 03:22:15 PMI feel pretty stupid.  I was doing configuring F8, but I have an K8.  But, so happy it is an easy fix.  thanks so much, you are the best.
Don't feel too stupid.  You are not the only one that has done that...
Remote Player Audio Playback by james-s
Today at 01:46:54 PM
FPP OLED Display by james-s
Today at 01:35:53 PM
FPP Volume Set not scheduling by JonD
Today at 06:09:58 AM
PI cannot find my F48 by JonD
Today at 03:55:58 AM
State of falcon pi cap? by darylc
Today at 01:45:10 AM
How to get deep purple color on pixels? by jchuchla
October 02, 2023, 09:29:03 PM
Looking for some clarification by MikeKrebs
October 02, 2023, 09:25:25 PM
After upgrading to v7 I now see Forbidden when trying to connect via web browser by dkulp
October 02, 2023, 05:05:07 PM
FPP 7.0 Released! by tbone321
October 02, 2023, 04:33:05 PM
error uploading sequences by woody
October 02, 2023, 04:10:41 PM
