Total Members: 15299
Latest: Psonic
New This Month: 2
Total Topics: 15247
Most Online Today: 78
Guests: 43
Total: 44
Serial Port Channel Numbers
Started by djmc2002, November 28, 2020, 12:19:06 AM
djmc2002
Hey might be a dumb question but I'm new to using serial port on my F16.  How are they numbered? So for instance I have 10 3 channel floods lights and 2  6 channel fog machines defined in xLights starting at universe 26 channel 7. I then have a mega tree that is set to chain after the last fog machine.  My first flood is defined as 26:7 (13267) and my last fog machine is  26:48 (13308)- mega tree defined as 26:49 (13309)
Is this the proper set up? I'm having strange problems that would seem to indicate I have a channel count off somewhere but I have check, rechecked, gone from full xLights control on the controller to me manually putting in every number and chaining models,  I'm stumped and wondering if the serial port thing is the issue since I have no past experience with them.
Thoughts and thanks!
pixelpuppy
On the F16 are you using Absolute Channel mode or Universe/Start Channel mode?
And what do you have the start channel set to on the serial output port on the F16?
djmc2002
Quote from: pixelpuppy on November 28, 2020, 07:38:26 AMOn the F16 are you using Absolute Channel mode or Universe/Start Channel mode?
I've tried it both ways -currently set to absolute- serial port is set to output 2 and channel 7
pixelpuppy
Quote from: djmc2002 on November 28, 2020, 10:11:25 AM-currently set to absolute- serial port is set to output 2 and channel 7
Not sure what you mean by "output 2" unless you mean Serial port 2.
If you're set to absolute channel mode and you set the serial port start channel to 7 then that DMX cable is going to start at absolute channel 7 but in xLights its absolute channel 13267.
It will be easier for us to help if you can post screenshots of how you have it configured.  Otherwise we are just guessing back and forth
djmc2002
Yes I should have done that in the beginning My bad.  Here is the set up pictures
djmc2002
Actual I did notice a error on when I was looking at the pictures and changed the address of the "santa house floods" to match xLights on the F16. - Can someone give this the idiot check look over and see if I janked it up some where or if it appears basically correct
djmc2002
One other question about serial port set up, if I'm driving LOR controller with DMX is each LOR channel "1" channel or "3" as is normal with DMX?
pixelpuppy
do your DMX floods have a settable DMX address?  Most DMX devices have a set of DIP switches to set their starting address.  That will need to be set to 7 in order to match your configuration.
Some DMX devices don't have a settable start address.  In that case you need to set your serial output to start on channel 13267 (the start channel for the 1st flood) and not 13261(the first channel of the Universe)
djmc2002
Quote from: pixelpuppy on November 28, 2020, 02:38:34 PMdo your DMX floods have a settable DMX address?  Most DMX devices have a set of DIP switches to set their starting address.  That will need to be set to 7 in order to match your configuration.
They are not addressed, (dumb) driven off a 27 channel DMX node controller (this is set to dip switch "7")
djmc2002
Just as a update, I discovered after getting the advice above that I not only was I addressing the serial port incorrectly (I was using the start of universe instead of the dmx channel number) I found that when I used full control auto size that my first controller was set to a total of 20 universes but what was required was actual 21 when you just added channels end to end. I never checked that channel count universe count until I went back on the dmx channel question I addressed in the OP. IT was at that point I discovered that auto size had set all the controllers to a incorrect number of universes.  (don't know if it is a error in the program, prob a error on my set up), but all the same it was a total number of universe issue.  Thanks for guidance and perhaps my problems can help others. -- Dave
Today at 01:39:26 PM
Today at 01:26:22 PM
Today at 01:13:37 PM
Today at 10:59:19 AM
Today at 05:34:34 AM
October 01, 2022, 10:24:15 PM
October 01, 2022, 08:31:43 PM
October 01, 2022, 08:57:49 AM
October 01, 2022, 07:49:10 AM
