Total Members: 15299
Latest: Psonic
New This Month: 2
Total Topics: 15247
Most Online Today: 78
Guests: 41
Total: 42
Pixel 1 port 1 won't light
Started by Santacarl, May 10, 2022, 09:57:55 PM
Santacarl
Hey All,
I am testing pixels and set up an F16V3 with 4 ports identically for testing 4 string at a time.  Ports 2-4 work perfectly but Port 1 will not light up pixel #1 in the string of 100.  And yes, I tried another string (same result) and also tried the same string on another port and pixel 1 works.
I checked and there is not a null pixel assigned to that port in configuration.  I also connected another pixel at the end of the string to see if the controller would push over into pixel 101; but it did not so only 99 pixels on the string light up.
I've included an attachment of the Port Configuration page in the Output Settings tab as I know there will be questions.
The E131/Artnet tab has 4 universes each sized at 510.  I tried switching the number to 300 to match identically the number of channels on port 1 but it did not make a difference.
Seems weird and I suppose I could solder in a null pixel and change the count to 101 pixels but that's problematic in itself.
Is there some other place that I'm forgetting about that could cause this?
Thanks...
Kensington Graves
It sure sounds like a channel offset problem.  I'd also check the start channel under the E1.31 settings to make sure that universe starts at channel 1 and not channel 4.  One of those obvious things, but I've missed things like that.
Santacarl
Quote from: Kensington Graves on May 10, 2022, 10:24:43 PMIt sure sounds like a channel offset problem.  I'd also check the start channel under the E1.31 settings to make sure that universe starts at channel 1 and not channel 4.  One of those obvious things, but I've missed things like that.
Thanks for the response Kensington..
So how do you change channel setting in the E1.31 tab?  The only options I see in the addressing mode are either Universe/Start Channel and Absolute....it doesn't let me see what channel it starts on....or am I looking in the wrong place?
If you are testing directly from the F16, there have been some known issues in the test function. Are you selecting all strings? Try testing from xLights.
Santacarl
Here's a weird twist.
If I go to configuration and set port 1 to start on channel 2 or 3 and set the color to white....the first pixel lights up blue.....
Santacarl
Quote from: Poporacer on May 10, 2022, 11:00:12 PMIf you are testing directly from the F16, there have been some known issues in the test function. Are you selecting all strings? Try testing from xLights.
Yeah...testing directly from the F16.....and based on your other question....I selected ALL ports instead of 1 only and now it's working....
Thanks Poporacer.....at least I know now....and won't think I've lost what's left of my mind..
Quote from: Santacarl on May 10, 2022, 11:03:20 PMand won't think I've lost what's left of my mind..
I replaced the first pixel TWICE on my Mega tree before I found out about the bug.... The first time, I didn't test the pixel beforehand, so I thought I replaced it with a bad pixel, but then when I replaced it with a known good pixel I figured something was wrong.
Today at 01:39:26 PM
Today at 01:26:22 PM
Today at 01:13:37 PM
Today at 10:59:19 AM
Today at 05:34:34 AM
October 01, 2022, 10:24:15 PM
October 01, 2022, 08:31:43 PM
October 01, 2022, 08:57:49 AM
October 01, 2022, 07:49:10 AM
