Total Members: 15492
Latest: Robnation13
New This Month: 5
New This Week: 28
New Today: 5
Total Topics: 15585
Most Online Today: 66
Guests: 18
Total: 19
Unable to change program to universe 1 and 2 from universe 2
Started by Frankr, November 28, 2015, 05:28:48 PM
Frankr
Hello all,
Trying to switch an F16 that is currently set to universe 2 only to a configuration that can use universe 1&2.
Using configuration software 1.2.3 and most recent firmware for FPD and F16
I can apply a program change to universe 2 just fine but when I try to apply a configuration that uses 1&2 it fails.  If I try to program to use universe 1 it fails.  The jumpers are selecting universe 1 & 2 on the board.
Can anyone point me in the direction of what I am missing?
Thank You,
Frank
JonB256
It could be a CAT5 cable problem.  The Orange/OrangeWhite pair are responsible for Universe 1 and they may be bad.
In case there may be something wrong with output jack #1 on the FPD, you could configure output jack #2 to match #1 and move the cable?
Frankr
Thanks Jon!
I had already tried the other FPD jack. Didn't think about the cable being bad. I will have to give that a shot in the morning. I wonder if I might have a bad solder joint for universe 1.
Frank
Frankr
In case anyone wants to follow along...
Cable swap no go. Tried programmming to uni 3 no go.
Broke out the ohm meter and tested from rj-45 through the uni selectors to the rs-485 chip and have continuity all along the way. At this point highly suspicious of the rs485 chip. Will see if I have a spare and try swapping.
Frank
drlucas
Failing that I assume you swapped power supplies on the FPD? Mine has been very sensitive to the brick I use supplying power.  Also make sure that in your FPD setup you have all the pixel net universes setup properly.
Sent from my iPhone
Ryan
JonB256
Quote from: Frankr on November 29, 2015, 10:11:18 AM
Frank
It is very possible that the RS485 chip is bad. There are a total of 12 on the FPD so finding one to swap should be easy.
If you (or a helper) ever plugged in a CAT5 cable from a Powered Hub, it may have killed the chip.
Frankr
The suspect RS485 is on the F16.  The FPD is doing great for all of my devices. Its only this one F16 on the universe 1 or 3 that is flaky.
For now I have relegated this unit to only use universe 4 and that will work for this year. A swap of the Rs485 with a DSC that unwillingly donated it did not improve universe 1 or 3 situation...
This is why I always have more supplies than I need :)
Frank
Unable to donate on PayPal by Mat-Moo
Today at 01:10:10 AM
Fpp 6.2 ui password by Mat-Moo
Today at 12:42:53 AM
Pi zero 2w by Sawdust
Today at 12:25:33 AM
I'm Stumped by saleencb
November 30, 2022, 11:49:40 PM
November 30, 2022, 10:58:43 PM
November 30, 2022, 09:27:58 PM
Very unexpected error message by tirebytrlights
November 30, 2022, 09:23:37 PM
Standalone Mode - limitations? by darylc
November 30, 2022, 09:21:04 PM
November 30, 2022, 05:21:55 PM
VAST-FMT/Si4713 plugin 4.1 by sgmaitland
November 30, 2022, 04:43:46 PM
