Total Members: 16872
Latest: Ninefingers
New This Month: 11
New Today: 2
Total Topics: 16969
Most Online Today: 102
Guests: 50
Total: 50
Wemos relay control
Started by Irvinlyons, December 17, 2024, 08:01:49 AM
Irvinlyons
Hi i am having trouble getting my 8 channel ssd relays to work with FPP. My setup is based on "Gary Mueller's /ESP-131GPIO relay driver config"
https://github.com/garymueller
I do have multiple relays that helps assist in turning on and off props this setup works great between vixen and xlights. Through FPP Ive tried using unicast or multicast and all i get is a flicker on a the relays ive checked all my numbers and ive checked the universes made sure that the all protocols matched such as multicast or unicast it just seems like im missing something else in my configuration. Any help would definately be appreciated. Attached is my fpp output and my vixen layout.
MikeKrebs
Do you have it hooked up to serial? What are you seeing there?
Did you set digital to true?
Gary Mueller
I use this in xlights without issue.  There is some documentation that may be helpful under https://github.com/garymueller/ESP-131GPIO/issues/4
Gary Mueller
I just noticed that your issue is from fpp, not xlights.  I have tested setting a specific channel from fpp before to turn on a ac prop and it seemed to work without issue.  Is FPP set to blank the channels after a sequence ends? Maybe thats your flashing?
FPP Spixels bug by Colg
January 31, 2025, 02:52:05 PM
