Total Members: 15303
Latest: markuslott
New This Month: 6
New This Week: 4
Total Topics: 15257
Most Online Today: 99
Members: 5
Guests: 59
Total: 64
Another u idea
Started by lrhorer, January 10, 2017, 11:04:42 PM
lrhorer
   Hey, I just thought of another idea.  This one would be ultra-inexpensive and I bet very popular.  It is just one of the pitfals of this hobby it requires soldering - lots and lots of soldering.  Now I don't mind board soldering and most connectors are pretty easy to solder with good, reliable results.  What I really hate, however, is butt splicing.  Of course there are crimp butt splices, but especially in small wire sizes and particularly low strand count wires, they are just not reliable enough to suit me unless I also solder them.  They are also rather expensive when one adds up three splices per joint times dozens of joints.  Your uAmp boards are extremely easy to solder, however, and highly reliable.  A bit of 3/4" heat shrink tubing makes them rain proof.  My idea is to create Printed Circuit board just about the same size and layout as the uAmp, but with no electronics, at all.  All they would have is three traces from one side to the other of the board, including the same strain relief holes as on the uAmp.  A 4 port version for 4-wire deployments would be good, too.  In quantities, I would think these could sell for under $1.  I know I would buy them.
bcstuff
-Brian
-------------  2020 - Keep adding more stuff, 2019 - added 70 lil' stars and 11 mini spinners to roof, Past - 16' Megatree, 8' MidiTrees, 8' MegaWreath, 6' Snowflake Spinners, Zwilluminaries™  Our Display Videos: http://vimeo.com/brianandheather
JonB256
Quote from: bcstuff on January 10, 2017, 11:26:30 PM
Check out the PST (Pixel Splice Tap)
https://holiday.lighting/
I got some of these when they first appeared. They are exactly what lhorer is asking for (and cheaper). The 4 wire version is new to me, though.
Sadly, mine sit in a ziploc bag. I keep forgetting I have them when splicing. :(
drlucas
I ordered a bunch last year and didn't use mine at all.....for my in yard/show season repairs I use these from Ray... https://www.aliexpress.com/store/product/3pin-10mm-width-connector-for-10mm-wide-pcb-led-digital-strip-ws2811-ws2812b-etc-no-need/701799_32389247007.html?spm=2114.12010608.0.0.QMNGUm
What I do though is pretty rough...I strip the wires down...and then twist the wires together and put them inside the clip and use it as a clamp to keep the wires together. I end up using three of them per repair.
In previous years I've used small electrical marrette nuts (http://www.tnb.ca/en/brands/marrette/) and the butt splices with mixed results (mostly because I didn't have a crimping tool for the butt splices - just recently ordered one so next season that is another alternative for me).
I suppose the PSTs are great, but for me in the middle of winter with a foot of snow on the ground it's hard to get out with a soldering iron and even harder to pull a prop and bring inside for the repair.
Ryan
I ordered a board of the PST's when they came out as well, and they still sit in the envelope they were delivered in.  When it came to soldering together 100+ pigtails or splices, I chose speed and convenience over cost and just used the solder sleeves rather than having to put hundreds of wires in PST's and soldering each wire individually.
nmiller0113
Quote from: lrhorer on January 10, 2017, 11:04:42 PM
I crimped hundreds of these this year anywhere from 18 to 20 AWG of stranded wire without an issue...NOT A SINGLE ISSUE
https://www.amazon.com/gp/product/B01CNFJK0A/ref=oh_aui_detailpage_o08_s01?ie=UTF8&psc=1 using https://www.amazon.com/gp/product/B0006M6Y5M/ref=ox_sc_sfl_title_3?ie=UTF8&psc=1&smid=ATVPDKIKX0DER
No additional solder and they worked perfectly.  Nor are they expensive at all.  From years of crimping and moving to this, this year I've gotta say this is just as reliable, if not more, than soldering and a million times less time consuming than regular soldering or even what you're proposing.  There were a ton of us, including David Pitts, that moved to these this year with much success.  So I've got to respectfully disagree with your assessment of butt crimping.
lrhorer
As always, your mileage may vary, and of course you are absolutely entitled to hold whatever opinion you like, but I have crimped many tens of thousands of connections over the last 40 or so years, and crimp connections on small gauge, small strand count wires are just not reliable.  Using a high quality ratcheting crimper will without question produce the best results without soldering.  We frequently crimp cables from 6 AWG to 1" diameter using hydraulic crimpers, and I can pretty much guarantee you those will not fail even under very severe stress.  In some cases, the wire will part before the splice fails.  High strand count wires also produce excellent results.  Ordinary 16 AWG lamp cord, for example, can be crimped quite securely even using simple, non-ratcheting crimpers.  Anything smaller than 18 gauge, or with fewer than 7 strands, however, just cannot be crimped reliably enough to suit me, unless I both crimp and solder, which I usually do.  If I can grab both ends of the crimped wire and cause the crimp to fail just by exerting a steady pressure with my hands, then it's not good enough in my book, and I have yet to come across a crimper / splice combination that produces acceptable crimps on solid 22 - 28 AWG cable (Cat5e is 24 AWG) or even the 20 AWG stuff we buy from RayWu.
nmiller0113
I think that one thing you're failing to take into account is the fact that the connectors I mentioned not only heat shrink but also glue. The middle part is providing connectivity and grip and then the glue and heat shrink very securely locks it in place. I cannot pull apart stranded 20awg. And I've tested it. Yes. My opinion, but it's not pulling apart and the connectivity is solid.
lrhorer
I'll give them a try.  Of course, 20 AWG stranded is right on the edge of where the problems start, and these might well cover that application effectively.  The vast majority of my connections are solid 24 AWG, however, and those connectors are only good to 22 AWG.  I think I would definitely decline to use them on 22 AWG solid wire.
corey872
Give them a shot.  Truthfully, every splice I've ever made for a node is:
- Cut the wires in prep for splicing (ideally one longer side  - call it "A" and a shorter side, call it "B", but maintaining the same node spacing as original)
- Strip 1/8" insulation from each wire end.
- 'Tin' both individual ends with solder.
- Slip 'double wall' (adhesive lined) heat shrink over the "A" (long) wire end and use the extra length to slide it far away from the heat of soldering.
- Gather a small drop of solder on the iron, touch the two wires together, then touch the iron to the joint.  The wires and solder should instantly form a small blob encasing the wires.
- Pull the iron away and hold the wires still while the joint sets.
- Once cool, slide the heat shrink over the joint and heat to seal.
This has the benefit of being fast, cheap (literally a drop of solder and 1" of heat shrink tube), nearly invisible (no big bulge in the wire), and nearly as flexible as the original wire.  I've never had one of these joints fail due to mechanical issues or moisture intrusion.  On a couple of 'pull tests' I did, the wire breaks before the solder joint, so it is certainly 'as strong as needed' for the given conditions.  If you're super paranoid, you could add a second layer of heat shrink over the whole 3 or 4 wire bundle to seal each of the individual joints a second time.
Corey
plaberge
In my shop, I splice them exactly as Corey does. I've too have never had a splice failure and I'm sure I've done more than a thousand. If I have to make a splice outside, I use telephone cable connector crimps. They're bulky but they're fast, secure and waterproof.
Paul.
Halfmoon Bay, BC
JonB256
Quote from: plaberge on January 12, 2017, 11:34:53 PM
In my shop, I splice them exactly as Corey does. I've too have never had a splice failure and I'm sure I've done more than a thousand. If I have to make a splice outside, I use telephone connector crimps. They're bulky but they're fast, secure and waterproof.
Just used these telephone crimps (I only buy the 3M brand, not the super cheap clones) to replace the three bad Pixabulbs in my Megatree. Tested fine. Put away until November. As long as there is no stress on the wire (like in a boscoyo strip or matrix), these will last forever and are so much easier than anything else.
Now, if anyone ever makes (or knows of) one that will do all 3 wires in one similar package, I'll be interested.
plaberge
Quote from: JonB256 on January 13, 2017, 08:57:37 AM
That would be very handy, especially if you didn't have to strip the wire  :D
Paul.
Halfmoon Bay, BC
FPP Advanced Features Key has been used. by tfmacz
Today at 10:44:55 AM
DIY voucher request by steve123
Today at 09:14:32 AM
Written documentation for Differential Receivers v2.01 by JonD
Today at 09:04:50 AM
Docker Container - No Multisync Discovery by EricD
October 04, 2022, 10:51:15 PM
Unable to reconnect to BBB after network config by Stoshx
October 04, 2022, 06:33:05 PM
WTB F16v4 by Poporacer
October 04, 2022, 02:31:40 PM
F16V3s for Sale by Manuelpereyra78
October 04, 2022, 12:33:36 PM
October 04, 2022, 09:54:36 AM
House preview - full screen icon missing by JonD
October 03, 2022, 06:03:37 PM
F26V3 Unable to connect to network by JonD
October 03, 2022, 05:52:09 PM
