Total Members: 15497
Latest: packhawk
New This Month: 5
New This Week: 33
New Today: 5
Total Topics: 15589
Most Online Today: 128
Members: 4
Guests: 109
Total: 113
uAmp use for 24v Floodlights
Started by jhoybs, October 05, 2017, 01:36:05 PM
jhoybs
2 questions on the uAmp
1) I'm using it for RobG's 20W WS2811 floods - they are 24vdc.  I've placed a series 5.6v Zener diode in line with the power input of the uAmp to reduce the voltage that it sees to get some voltage headroom (read that 24vdc is max input voltage).  Will this be OK?
2) I'm installing the uAmps in line and my cabling will vary from 15-40 feet.  Am I better off placing the uAmp on the data inputs or outputs of the flood (currently, I have my first prototype on the input)?
Jim H - Muskego, WI
Falcon F16v3, F4v3, PiCap, FPPs. Lynx Expresses, xLights
mklabunde
Jim,
  Zener diodes are put across the load with a resistor in series with the zener to limit the current draw.  Do a google search of how to hook it up.  You are on the correct track just have to add one part.  I think that putting the micro amp closer to the output of the controller is better.   More signal for that micro amp to work with.
Mark
Bwinter
The 50w version on the 24v floodlights are recommended to actually run at 27v.
Can anyone simply explain what would be needed to use a uAmp in this scenerio?
zwiller
First thing that pops in my mind is to use step up buck.  Run 24V into uAMP and to flood but use the buck at the flood and raise to 27V.
Sam
Bwinter
Quote from: jhoybs on October 05, 2017, 01:36:05 PM
In your set-up, what would be the benefits/differences of using a set-down buck-converter in place of the Zener diode?  I'm in a similar situation, where I'm using 27v-28v (for the floods) but my uAmp is limited to 16v.
My (limited) knowledge was that the uAmps are indented to work on the output-side, in order to send the signal a greater distance.
jhoybs
Quote from: Bwinter on October 21, 2017, 02:30:57 PM
This is what I am doing - I used a Zener circuit to drive the uAmp.  I placed it inside the flood.  I'm using 14 guage power cable for the 3 lines.  Note: Doing it over again, I'd suggest a resistor value of 1K.
Jim H - Muskego, WI
algerdes
FYI - just for general knowledge:
A "buck converter" is a DC to DC step down unit. (Higher voltage to lower.)
A "boost converter" is a DC to DC step up unit. (Lower voltage to higher.)
jhoybs
Good point.  Normally, I would have used buck convertors, but I had Zeners & resistors on hand.
Jim H - Muskego, WI
