Total Members: 16522
Latest: MrLV83
New This Month: 10
Total Topics: 16546
Most Online Today: 37
Guests: 24
Total: 24
Clock for Offline Scenario
Started by Noxx, May 05, 2024, 06:23:40 AM
Noxx
I want to use FPP on a Raspberry Pi 4 with an F16V4. I will not have Internet during my shows.
How can I add a clock? I saw that there are hats/components that provide an off-line clock, but they seem to need some commands for installation that seem to be easy to use on RaspberryOS, but how could I install them with FPP?
Thanks!
It is a simple setting in FPP, no commands needed. Jou just the too select the type of clock you are using.
https://falconchristmas.github.io/FPP_Manual.pdf#page=64
Noxx
Ok, thanks for the fast response.
If I understand it correctly, I can set a time manually.
But what happens if the Raspberry is not continuously powered?
Without battery, it probably forgets the time and needs a new manual setting, right?
If so, what is the best way to avoid that? That's why I looked for an extension for the Raspberry.
Or do I misinterpret the situation?
If the PI looses power it will lose time.  You can set it to pull from another local device that does not loose time in a power outage using the NTP service, or you can install a realtime clock hat on the PI.  If you install a Pi hat, you would just select the one you have from the drop down.
Is there a reason that you will not have internet during your show?
Noxx
@Poporacer: Yes, the reason is that we will run the show at Burning Man in the desert of Nevada. Not many cellphone towers there :-)
Thanks @JonD: so, you are saying a Pi hat doesn't need an install in an OS, but just a selection in FPP. Sounds good, I'll look out for an appropriate hat.
Quote from: Noxx on May 05, 2024, 11:32:13 AMYes, the reason is that we will run the show at Burning Man in the desert of Nevada
OK, that makes sense!
Quote from: Noxx on May 05, 2024, 11:32:13 AMyou are saying a Pi hat doesn't need an install in an OS, but just a selection in FPP
That is correct
breese
This is the external clock I use and it works really well.
Also, if you get a rechargeable battery for it, when the PI is powered on it will recharge the battery.
https://a.co/d/e0AOu4b
No data lights on smart receiver by glm441
Today at 12:37:03 AM
FPP 8.0 Released! by Santacarl
September 11, 2024, 10:24:19 PM
New K16s by tetleytealeaf
September 10, 2024, 08:36:29 PM
Setting up FPP and Xlights to talk to PCA9685 (Servos) by Poporacer
September 10, 2024, 05:21:56 PM
Can I control 12 volt WS2811 Pixels with the PI Hat. by tbone321
September 10, 2024, 04:06:04 PM
P5 Matrix on FPP 8.0 help by cmora111
September 10, 2024, 02:27:47 PM
Falcon srx1 psu problem by Vet4Christ
September 10, 2024, 04:34:56 AM
HELP - Panels Blown or PocketScroller messed up by DaSarge
September 09, 2024, 05:03:25 PM
Lights don't work on K16 by jnealand
September 09, 2024, 07:23:53 AM
LED Panel issue after upgrade to v8 by k6ccc
September 06, 2024, 05:54:33 PM
