Total Members: 16523
Latest: Hotrodnick
New This Month: 11
New This Week: 3
Total Topics: 16548
Most Online Today: 31
Guests: 20
Total: 21
Still Network issues
Started by TravisSlaughter, November 25, 2023, 12:40:14 PM
TravisSlaughter
I cannot connect on a switch. Ive tried dumb switch no connection. The smart netgear switch and doesn't complete the handshake. What is the issue are we getting a firmware update to fix the issue or how can I connect this on the same network. It seems to be trying to connect via wifi but cannot transmit the e1.31. This is frustrating to say the least
#1
You can't really run a show directly over wifi.  Maybe you could run a few lights, but there is typically too much latency.  People do run wifi shows in a Master/Remote Multisync solution.  Where the files are transfered directly to a local SD card and the master FPP player tells the controller when and what to play.  It just transfers minimal timing data over the network in that situation.
The Falcons multisync wifi solution has been problematic, and many people have complained about issues.  If you want assistance with the Falcon Wifi, you will need to reach out to Falcon support at https://pixelcontroller.com/store/content/13-support2
If the network card is not connecting to the ethernet port... it is either cable, firmware, switch, or defective controller.  Ethernet ports can burn up and it is possible the network card on the controller is defective.  You could reach out to Falcon support directly, or possibly the xlights zoom room at https:\\xlights.org.
TravisSlaughter
Im not trying to connect via WiFi nor run the show. The controller is not working with any network switches. (Smart/Dumb) either one. The issue is I can get the controller to connect as long as it is directly in my wifi extender but that means I cannot connect any of the other elements (fpp remote on bbb and fpp master) its one or the other. If I had the 48v4 instead of the NS version it would be ok because I could throughput data but i cannot on this board.
TravisSlaughter
Make sure you set a smart switch to 10m all ports .  I think it's working now we shall see!!!
#4
Quote from: TravisSlaughter on November 25, 2023, 01:55:22 PMMake sure you set a smart switch to 10m all ports .  I think it's working now we shall see!!!
Glad you got it going!  Are you building your own network cables?  If so, make sure you are following the correct wiring standards.  10mb only is often a sign that you have cabling issues or that the cable end is not wired correctly.  The correct pinout is critical on the cable.  If you are wiring them straight through, the transmit and receive pairs are not twisted and that will cause performance issues and prevent the devices from connecting at 100mb.  Also, how long is the cable?  Excessive length would also cause these type of issues.
K2-Pi0 Unable to Start FPPD by ironsniof
September 12, 2024, 09:54:36 PM
No data lights on smart receiver by tbone321
September 12, 2024, 03:56:57 PM
FPP 8.0 Released! by Santacarl
September 12, 2024, 02:24:02 PM
GE iTwinkle by Hotrodnick
September 12, 2024, 02:12:38 PM
New K16s by tetleytealeaf
September 10, 2024, 08:36:29 PM
Setting up FPP and Xlights to talk to PCA9685 (Servos) by Poporacer
September 10, 2024, 05:21:56 PM
Can I control 12 volt WS2811 Pixels with the PI Hat. by tbone321
September 10, 2024, 04:06:04 PM
P5 Matrix on FPP 8.0 help by cmora111
September 10, 2024, 02:27:47 PM
Falcon srx1 psu problem by Vet4Christ
September 10, 2024, 04:34:56 AM
HELP - Panels Blown or PocketScroller messed up by DaSarge
September 09, 2024, 05:03:25 PM
