Total Members: 15733
Latest: aquila2heman
New This Month: 0
Total Topics: 15886
Most Online Today: 125
Guests: 123
Total: 124
BRP Voting Plugin - Allow others to vote for your songs!
Started by Barkers Random Projects, January 05, 2020, 04:25:16 AM
Quick update
  • Install python 3 when installing the plugin - the most recent version of fpp on the master branch doesn't appear to have this version installed on it anymore. Python 2.7 support ended on January 1, 2020 - so I'd like to stay with a maintained version.
Checkout what else we are working on at https://barkersrandomprojects.com
vcuncg
This plugin is great and simple to set up and use.  Thanks for all the hard work!  I did have one question to see if it is possible to add.  Can the service auto-restart after a reboot?  Maybe I can use a script to fire it when my show starts if it is not running already?  I typically leave my pi up and running all season, but occasionally I do reboot for one reason or another.  Would be nice to have it auto start since I would probably forget.
Thanks again for this plugin!
I just got around to trying this again and I still do not get a voting URL. When I generate the key and start service, I get the spinning icon that it is retrieving the URL but it never returns. Here is the error log.
root - INFO - Private key: 8f7dbba2-a462-4a83-a9fa-656aaf5d46d1
root - ERROR - Problem getting status! 'next_playlist'
vcuncg
@Poporacer I had a similar issue.  To solve it, I started a playlist and while it was running I went to the BRP plugin and started the service.  Then it created a URL for me.  From then on it has worked like a charm.  Hopefully that will help you too.
Quote from: vcuncg on May 26, 2020, 02:46:36 PMTo solve it, I started a playlist and while it was running I went to the BRP plugin and started the service.  Then it created a URL for me.
That worked as well. Thanks!
It looks like someone can vote for one song more than one time? That isn't good. People should only get to vote once for a song.
SCUBA
I've come back to the plugin.... A couple of questions and observations
1) Do I need to load Pytrhon 3 and if so how do I load it?
2)I'm not getting a key.  I try to generate a key and nothing happens.  I'm using Safari. I tried switch tabs and coming back to th e plugin but no joy.
3) I tried the trick with starting a sequence then starting the service but no URL is displayed; most likely due to the key not being generated.
RPI: 3B+
v4.x master-362-g85aa2d29
SCUBA
BTW: are there any conflicts with MQTT/home assistant or Remote Falcon?
vcuncg
SCUBA - it should load Python 3 for you as a part of the install.  The install script has the following two lines, so you could try doing an SSH into the FPP player and running the following lines:
sudo apt-get update && sudo apt-get install -y python3 python3-pip;
python3 -m pip install requests;
For conflicts with MQTT I do not see any yet.  I am using an MQTT broker in HA and testing things out.  Everything seemed to work well.  I have not messed with remote falcon yet, but plan to check that as well.  Hope this helps some.
SCUBA
SCUBA
There seems to be a few "limitations" with the website: number of sequences (it didn't display all of the sequences/songs in the playlist); position of the sequence that was "voted" (the playlist jumped to the bottom of the playlist and stopped).
Love the Snow effect!! perfect.
Will there be a version where we can upload a custom page?
See attached log
SCUBA
I did some testing of the plugin
Setup:
FPP Version:   v4.x-master-412-gc74d4825
Platform:   Raspberry Pi (Pi 3 Model B+)
FPP OS Build:   v4.0-alpha3
OS Version:   Raspbian GNU/Linux 10 (buster)
Hardware Serial Number:   00000000f159a975
Kernel Version:   4.19.97-v7+
Local Git Version:   c74d482 ChangeLog
Remote Git Version:   c74d482
1 The blue background doesn't go down the page all the way. Minor issue.
2) The list of sequences is correct, but it doesn't start at the top of the playlist.. Minor issue
3) When there is no voting the sequences are played in the correct order with the "dark" sequence playing nest: All good!
4)Voting: Single sequence voting appears to work as follows:
  • The sequence with the highest (or in the case of a tie the first sequence to reach the largest vote DOES NOT play.  Instead the sequence above (or before) it plays first, then the voted sequence plays....
log: You cannot view this attachment.
Thanks everyone for the testing, I'll get these things fixed!
#42
Ok I'm back at it. Finished up my automatic candy dispenser so I'm switching my focus to the plugin for this season!
Here is the changelog:
  • Fixed URL not resolving when no songs are playing
  • Fixed loading icons to work correctly
  • Adjusted timeout if server is unavailable to retry forever
  • Fixed note when indicating a new private key needs to be generated
  • Verified compatability with v4.3
Quote from: SCUBA on June 12, 2020, 12:53:17 PM
Thank you SCUBA for this and the logs. I've been able to reproduce this and I'll get it fixed.
The problem is that I'm not handling all of the cases where playlists have 'Lead In' and 'Lead Out' songs.
jwamsley07
I am running 3.6.2 and just installed it.  Seems to be running fine on my Halloween display.
June 03, 2023, 09:34:36 PM
Dmx by MikeKrebs
June 03, 2023, 08:53:35 PM
June 02, 2023, 09:36:11 PM
colorlight 5a-75b not working with raspberry pi4B fpp by MikeKrebs
June 02, 2023, 09:25:08 PM
EEEPROM Files by shanebou24
June 01, 2023, 01:27:06 PM
Kulp OctoPlus v2.3 by MikeKrebs
May 31, 2023, 10:03:21 PM
Weird latency over artnet by MikeKrebs
May 30, 2023, 09:50:12 PM
Discontinued P10 1/2 Scan Panel Issues by MikeKrebs
May 30, 2023, 09:40:30 PM
Fpp and xlights preview not working by bloojoop
May 30, 2023, 08:42:23 PM
hanson pi hat problems wih DPi pixels. by MikeKrebs
May 29, 2023, 09:12:13 PM
