Total Members: 15464
Latest: BroJam22
New This Month: 87
New This Week: 5
New Today: 5
Total Topics: 15541
Most Online Today: 107
Members: 7
Guests: 77
Total: 84
Raspberry PI direct connect LED Pixel to GPIO 18?
Started by CyberMicha, December 21, 2021, 01:04:50 PM
CyberMicha
Quote from: Poporacer on December 23, 2021, 01:38:23 PM
Quote from: CyberMicha on December 23, 2021, 01:32:12 PMI also tried with 50 pixels on port 1 but nothing happens. Very frustated
You need to start at the controller. Test from the controller, if the lights are not lighting up using the test function in the controller itself, then it is usually a wiring problem, pixels wired on the wrong end, V+, Gnd, Data not properly connected to the correct pins, cable length too far for the voltage/Data, etc.
Don't go any further if the testing from the controller isn't working first. You have to get it working there first.
But i have not Controller. I want to use the pi as Controller. The data connects directly to the Pixel data input
CyberMicha
Quote from: Poporacer on December 23, 2021, 01:33:20 PMThen go to the Visualizer and assign the models to the ports you are using by dragging them in the correct place and exit and Save
What do you mean with this? The Layout Tab?
Quote from: CyberMicha on December 23, 2021, 01:48:27 PMBut i have not Controller. I want to use the pi as Controller.
Yes, you have a controller.  In this case it IS FPP.  Use the test functions in FPP.  Until that works 100%, make no effort to test any farther away from the controller.
CyberMicha
Quote from: CyberMicha on December 23, 2021, 12:29:02 PMAgain my Settings.
You have some important items missing!
In xLights on your controller tab set your Vendor to FPP and Variant to Pi-Hat
Then set the Auto Layout Models and Full xLights control and Save
Once you do that, then FPP Connect will work properly, make sure you put a check in the Cape option in the far right of the screen.
THIS was the final hint! xLights was bad. Thanks a lot!!!!
