Total Members: 15486
Latest: Cousin_Eddie
New This Month: 108
New This Week: 22
New Today: 6
Total Topics: 15571
Most Online Today: 108
Members: 3
Guests: 48
Total: 51
Experience lights Pi Extender - who powers what?
Started by rwthib, April 08, 2022, 08:58:41 PM
rwthib
So want the Experience light pi input extender sits on top pi also passes along the pins so you can place another hat on top of it. Has anyone tried running both? And since they both have power input, any idea which one to power or power both?
Here is what I am talking about
https://experiencelights.com/raspberry-pi-input-extender-kit-pi-hat-node/
Kensington Graves
It appears to me that the hat most likely passes a power pin, a ground pin, and 6 GPIO pins from the RPI.  The hat can be powered from the RPi by setting a jumper, but it appears that the maker recommends a 12v external power supply if the matching receiver is set any significant distance from the RPi.  Also, the hat is only rated for 500mA, and nothing is fused on it.
The Falcon PiCap will back feed the RPi if the jumper is set to do so.  For 7v to 24v external power supplies, the back feed occurs through a voltage regulator.  The PiCap is fused at 2A to protect onboard components, but it will pass at least 1.5A through the back feed to the RPi.
I probably wouldn't try to feed both the RPi and the hat from the PiCap just because the PiCap only feeds 1.5A and RPi Gen 3 and up can consume that much and more.  Drawing another 500mA for the hat reduces the current too much, IMHO.  I'd jumper the hat to use an external power supply and power only the RPi from the PiCap.  If you are using a 12v external power supply for triggers (as recommended by the hat maker), you'd be jumpering the hat to external power anyway.
Also, the setup video seems to indicate that it's almost a foregone conclusion that you'll use external power.  So my proposed setup would be jumper the hat to external power, run power from a 12v PSU to the hat, jumper the PiCap to 7v-24v and jumper it to feed the RPi, and connect the PiCap power posts to the 12v PSU.
Today at 05:54:00 PM
Today at 05:42:57 PM
Today at 05:42:01 PM
Today at 05:41:06 PM
Today at 05:11:29 PM
Today at 04:52:18 PM
GPIO by darylc
Today at 04:44:02 PM
Today at 04:07:18 PM
USB Wifi Adapter by jem5136
Today at 02:15:45 PM
Today at 01:41:55 PM
