Total Members: 15492
Latest: Robnation13
New This Month: 114
New This Week: 28
New Today: 6
Total Topics: 15583
Most Online Today: 97
Members: 5
Guests: 64
Total: 69
Mega tree - lights not working in xlights
Started by Geod, September 29, 2022, 01:06:58 PM
Geod
I am trying to add a mega tree to my sequence.  I am using a falcon f16v3 controller with an additional 16 ports.    The lights light up correctly when I test them on the controller.    See attachment on how I setup the controller
The mega tree (small one) had 10 sets of lights each containing 50 lights (25 going up and 25 going down the tree).
However, the lights do not light up when I try them in my sequence.  The "lights on" icon is in the on position.
Let me know, if this doesn't make sense or you need additional info
Can anyone provide suggestions on what I need to change to get the lights to work?
GeodYou cannot view this attachment.
in xlights each string has a start channel of 1 and a universe number corresponding to the port number.  See screen shot attachment from xlights
Assuming you have a Falcon F16v3 and a Falcon 16 expansion (like the picture below) and not the 4 port differential expansion board.  In other words you are not using any smart receivers for any ports?  The top ports should be 1,2,3,4 and not 1a,2a,3a,4a.  Not sure if that will cause any issues, but does not look right.
In xlights you appear to be assigning universes, but on the falcon assigning absolute channels.
Believe you need to assign universes on the falcon e131 page, and then assign the universe number to the port.  Either that or use absolute numbers in xlights instead of universes.  Never used absolute numbers personally, but pretty sure you need to use one or the other, but not both.
Quote from: JonD on September 29, 2022, 01:34:45 PMThe top ports should be 1,2,3,4 and not 1a,2a,3a,4a.  Not sure if that will cause any issues, but does not look right.
I agree with JonD. I think you are making it WAAAAAAY harder than it needs to be. One thing that is an absolute necessity, is the xLights and your controllers match EXACTLY to the pixel, channel universe. xLights can actually do that for you and eliminate all of the problems that you are having.
Quote from: Geod on September 29, 2022, 01:06:58 PMThe mega tree (small one) had 10 sets of lights each containing 50 lights (25 going up and 25 going down the tree).
You didn't provide a lot of detail, so I need to make some assumptions, I assume that your tree is using 50 pixels per port and using 4 ports? You have the first two strings of pixels on that tree configured on a Smart Receiver and the rest on the main controller?? That seems extremely odd.
Quote from: Geod on September 29, 2022, 01:06:58 PMHowever, the lights do not light up when I try them in my sequence.
I am sure this is due to your controller not being configured correctly but it could also be your xLights configuration, Controller config, sequence not being saved....a Lot of variables can cause this.
Quote from: Geod on September 29, 2022, 01:06:58 PMin xlights each string has a start channel of 1 and a universe number corresponding to the port number.
I think you are misunderstanding what universes and ports are... There is NO direct correlation with Universes and port numbers so that is most likely ONE of your problems...Refer to my very first comment for the solution.
Quote from: Geod on September 29, 2022, 01:06:58 PMSee screen shot attachment from xlights
Please post screenshots and not links, it is much easier to see everything on one screen.
Quote from: Geod on September 29, 2022, 01:06:58 PMCan anyone provide suggestions on what I need to change to get the lights to work?
Learn how to use the tools in xLights like I mentioned so that everything matches. You might want to jump in the Zoom Room for some one on one instant help. Here is some information about the Zoom Room
Quote from: JonD on September 29, 2022, 01:34:45 PMEither that or use absolute numbers in xlights instead of universes.  Never used absolute numbers personally, but pretty sure you need to use one or the other, but not both.
You can use one both, but it is difficult to keep track of things and WAAAY to easy to convert them incorrectly, I feel like saying you are correct here so people don't try.... LOL
Geod
Thank you Poporacer and JonD.
You were correct.  I was making it WAAAAAY harder than it should be.
I changed to the falcon E131 page and assigned the universe number to the port and everything is working.
THANKS again
Geod
Quote from: Geod on October 03, 2022, 10:33:30 AMYou were correct.  I was making it WAAAAAY harder than it should be.
hmmm see below
Quote from: Geod on October 03, 2022, 10:33:30 AMI changed to the falcon E131 page and assigned the universe number to the port and everything is working.
LOL, then you are still making it WAAAAY harder than it should be. Once you get your Controller's network configurated, you typically do not need to get into it again! xLights will take core of your controller configuration for you.
Standalone Mode - limitations? by boknows
Today at 07:19:32 PM
Pi zero 2w by darylc
Today at 07:01:52 PM
Today at 05:21:55 PM
VAST-FMT/Si4713 plugin 4.1 by sgmaitland
Today at 04:43:46 PM
FPP connect by LedMutt
Today at 04:23:40 PM
Differential Receiver Board Ports w/ F48 corrupted data by tkelba
Today at 04:15:16 PM
How to tell if a pixel is going bad? by rayster
Today at 03:12:29 PM
K4-PB FPP Setup by K-State Fan
Today at 01:41:17 PM
Clock is slow by Rusackas
Today at 12:33:41 PM
FPP RPi 4 GPIO Big Button question by dkulp
Today at 11:22:26 AM
