Total Members: 17090
Latest: Cafin8
New This Month: 14
New Today: 2
Total Topics: 17174
Most Online Today: 339
Guests: 108
Total: 109
PocketScroller V2
Started by dkulp, August 26, 2019, 12:56:53 PM
For those that were on the xEssentials thing last Wednesday, you saw a new version of the PocketScroller.   Also, anyone that went to the Expo got to see them in action as the two panels that were running at the xLights booth were both running using the new PocketScrollers.   However, I hadn't had time to get them added to my store, but since stock of the "v1" is running very very low, I decided I better get them up there.  :)
Store link:
https://kulplights.com/product/pocketscroller/
So, what's new?   Well the obvious thing that is new is the optional OLED display.  Along with that are two push buttons (like my other controllers) for the menus and a temperature sensor.   I've kept the size "almost" the same (it's 1.5mm taller to make room for the buttons and oled connector).
Important note: The PocketScroller v1 uses EVERY SINGLE GPIO pins available on the PocketBeagle.  Thus, in order for the OLED to work, it has to share some GPIO pins with Port 6.   If port 6 is used to drive panels, the OLED will shut off once FPPD starts. Thus, if you need to use all 6 outputs, the usefulness of the OLED is diminished a bit.   However, if you don't use port 6, you get the full OLED status and menus.
I do have a question for everyone......
Should the default orientation of the WHITE OLED be "normal" (as in the picture") or "flipped"?     Basically, when mounted, would people expect the ports on the bottom and OLED to stick UP (so flipped would be better) or ports on top and OLED extends down (so normal)?
It easily changed in the settings, but the question is: what should the default be that is burned onto the eeprom?    Mostly just curious about how people mount the PocketScrollers and what people would expect.
TypingOffKey
For any board, I like to have power connections on the bottom where possible, so I would say stick with "normal" for the default.
Normal would be my suggestion - not that I have an OLED on mine...
FPP / BBB KULP OCTOSCROLLER by Keebler
Today at 06:48:41 AM
FPP After Hours Music Plugin has been updated by ornsclub
November 08, 2025, 08:51:06 PM
virtual matrix goes out after 3.20 mins by mrgimmeone
November 08, 2025, 05:43:30 PM
FPP Backup Setup by atdj1997
November 08, 2025, 06:35:04 AM
Remove 1 prop from all show group by starsman20
November 08, 2025, 05:57:45 AM
Portable Pixel Tester by Chicken
November 07, 2025, 10:07:36 PM
F16V3 Controller - IP Address 0.0.0.0 NO NETWORK CONNECTION by RTED
November 07, 2025, 07:53:40 AM
How to setup and configure controllers in xLights I have a few. by Poporacer
November 07, 2025, 06:59:09 AM
Random flickering of lights by Poporacer
November 06, 2025, 09:24:16 PM
WANTED: F16v5 / F16v4 / F16v3 — will pay / will ship to Matthews, NC by JonD
November 06, 2025, 12:21:35 PM
